WHATS UP WH THIS SUNROOF?
Old Jul 26, 2012 | 07:41 PM
heyhi's Avatar
It opens like it should. When I close it,it stops towrds the end and opens half way with the switch closed. I have to turn the ignition off and on and use the other switch to close it.
Old Jul 26, 2012 | 07:49 PM
Ghost_54's Avatar
if you have an 02-03 Max you need to reset the switch, now that you have it fully closed ... (you may hear two clicks) anyway (Hold down the tilt down (close tilt) button for three + seconds and try it again.) and all should be back to normal.
If you have an 00-01 I believe you have to disconnect the battery (for an 1/2 to one hour) someone jump in and correct if I am wrong regarding the 00-01 model years
Old Jul 26, 2012 | 07:51 PM
heyhi's Avatar
Its a 02 il reset it in the morning. I got stuck in the rain today and i had to pull over to close it.Thanks
Old Jul 26, 2012 | 07:58 PM
Ghost_54's Avatar
I fix my post above its not the auto open/close button you want to hold ... rather it is the tilt switch button you want to hold in the close possition for a couple of seconds
the reset procedure is in your owners manaul if you have one.
Old Jul 29, 2012 | 05:57 PM
WhoDatBuuL's Avatar
i never knew this thats how u reset it thas good stuff to know
Old Jul 30, 2012 | 09:08 AM
dfj240's Avatar
Yea, with those position selectable switches our cars have, they can get confused pretty easily if anything besides flawless operation happens. So the reset trick is a nice touch so that you can get it working again without major/stupid repairs. Lol. I've had to use it several times so far and I've only had my 02 for about 3-4 months.
-Nathan
Old Jul 30, 2012 | 05:58 PM
sascuderi's Avatar
You are correct..for the '00-01 you have to disconnect the battery. Just had to do this a few days ago for the first time on my 2000 I30, but only had to remove the neg on the battery for ~5 min.
Old Jul 31, 2012 | 08:23 AM
BigLou55's Avatar
I was able to reset my 00 sunroof using the button reset method and it worked. My sunroof wouldn't auto open or close, after I did the button reset procedure it was good to go.
Old Aug 1, 2012 | 04:49 PM
01SilverMaxima's Avatar
I have an 01 and used the reset method. No radio inputs lost. FTW
bigdogsteve
Jan 31, 2018 04:18 PM
Fbana41
Aug 29, 2016 12:18 PM
Forge277
Jun 13, 2016 09:26 PM
jonreidhead
Jan 6, 2016 09:38 AM
Vequity
Sep 10, 2015 05:26 AM
