atf overfill
Old Jul 30, 2012 | 09:25 AM
alowoner's Avatar
atf overfill
hello, i just changed my atf and in my haynes book it said ti fill up as much as is drained. i drained almost 6 qts. and filled up with same. this seems like alot. anyway, my car seems to be acting strange while shifting. could it be over filled?
Old Jul 30, 2012 | 09:43 AM
njmaxseltd's Avatar
Dipstick? It's there for a reason.
Old Jul 30, 2012 | 10:08 AM
This.
Old Jul 30, 2012 | 10:49 AM
alowoner's Avatar
yeah i am aware of the dip stick but i cannot get an accurate reading. ran the car for a good 30 minutes, checked it while it was running but the stick is saturated. i guess i really want to know is will an overfill cause my shifting to be abnormal?
Old Jul 30, 2012 | 10:51 AM
Amerikaner83's Avatar
overfill is just as bad as underfill, yes.
But if you had no shifting issues before, and put the same amount in, the level is not relevant.
What type fluid SPECIFICALLY did you put in? And how did you do it?
Old Jul 30, 2012 | 12:43 PM
alowoner's Avatar
i used super tech dex/merc III, and just did a drain/fill.
Old Jul 30, 2012 | 01:02 PM
Did you shift through all the gears when the car was in the air?
Stupid quetion, but you have an auto, yes?
Old Jul 30, 2012 | 01:37 PM
alowoner's Avatar
yes and yes, first through drive
Old Jul 30, 2012 | 01:38 PM
you are also supposed to go in N, R, and P as well...ALL THE GEARS
Old Jul 30, 2012 | 02:09 PM
alowoner's Avatar
yes, did that.
Old Jul 30, 2012 | 02:26 PM
Hmm...Don't know what to tell you.
Try going through all teh gears when you're at idle, several times. I've read a few posts that say this could help...
4 speed auto, yes? Did the 5th gen offer a 5 spd auto or was that with the 6th only?
Old Jul 30, 2012 | 02:38 PM
XeroX's Avatar
Hella internets
It could be possible that you flushed some damaged parts from the tranny when you drained out the old fluid. If you have the owners manual it gives you a step by step on how to get an accurate reading. I switched mine to manaul YEARS ago so i cant remember off top
Old Jul 30, 2012 | 02:46 PM
alowoner's Avatar
switched your transmission or switched your car from a to m?
Old Jul 31, 2012 | 04:24 AM
Finchum's Avatar
not sure if it will apply. but, i suggest lucas slip stop. it puts some friction material back into the fluid so your trans will work a little better.
Old Aug 2, 2012 | 10:15 PM
alowoner's Avatar
sahweet!!
thanks for the help!! drained about a quart and a half and it is running smooth!!
Old Aug 3, 2012 | 01:37 PM
XeroX's Avatar
Hella internets
Converted from auto to manual.
Old Aug 3, 2012 | 02:59 PM
bennuss's Avatar
I have the same problem and also measured exactly what I took out. Cant get a good reading on the dip stick. Any secret to it?
Old Aug 13, 2012 | 01:01 PM
alowoner's Avatar
i just researched how much is supposed to be in it. 4 to 5 qrts. since i know how much i put in, i emptied what i needed to. everything is good now. well, till my max totally died. onto the trouble shooting again. not tranny related. could be fuel pump, not positive yet.
mclasser
Aug 23, 2015 09:32 PM
max808
Dec 19, 2001 08:40 AM
Maximum Pursuit
Sep 27, 2001 04:31 PM
bill99gxe
May 15, 2001 07:31 AM
bill99gxe
Mar 23, 2001 09:36 AM
