Slight oil drip from pan
Old Aug 7, 2012 | 04:54 PM
Decoy036SPD's Avatar
Have a brand new pan, brand new bolts ... apparently one of the threads for the bolts is stripped and the bolt does not fully tighten. Oil is now dripping from this bolt hole at about a drop per minute. In a day it loses about a few ounces I would say.
I am not really sure how to correct this situation. Do you think I should tap the threads and see if the bolt holds correctly after that?
I was thinking of seeing if a nut can fit on the back of the bolt from the top and tighten it down that way. Any help would be appreciated.
Old Aug 7, 2012 | 05:17 PM
cjandura's Avatar
Helicoil!
Old Aug 7, 2012 | 05:43 PM
fishtale6spd's Avatar
Yea helicoil will me a dam good fix almost permenant
Old Aug 8, 2012 | 07:09 AM
ffcbairn's Avatar
Why not just replace the bolt?
Old Aug 21, 2012 | 06:25 PM
reading helps ... before you post.
I will try a helicoil
Old Aug 22, 2012 | 10:28 AM
foodmanry's Avatar
Da Roller Coaster!
Before doing the helicoil try tapping the hole to recondition the threads and use a new bolt. Sometimes this is all it takes. If that doesn't take then do the helicoil.
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
D Mason
Jun 21, 2016 04:43 AM
05RLS2
Apr 14, 2016 11:49 AM
