Need help! Removing vent about stereo. Any Tips?
Re: Need help! Removing vent about stereo. Any Tips?
Originally posted by BlackMax2k1
I'm pulling straight out after I lifted up. I'm really
pulling on it too!
pulling on it too!
Good luck
I got it thanks. Any suggestions getting the screws out
of the stereo? I think they must have some loctite on
them. Hair dryer? I don't want to wreck the screws
with a power screwdriver.
Originally posted by punkdork
Good friggin luck! I got about 4 or 5 out. The others I ended up drilling out. I thing God is involved in putting those screws in. Anyone have any helpful suggestions?
aren't those screws hex screws (that's what I call them)? They can be taken out by a ratchet and socket??? I haven't looked at them in a long time, but I was thinking you could use the socket to break them loose.
If that doesn't work, then get a drill and screw bit ... push on the back of it into the screw and hard as you can (I put all my weight into it) and then run it. If it starts to slip though, back off of the screws. You will strip the head. Also try putting some liquid wrench on there too...
Re: Re: Need help! Removing vent about stereo. Any Tips?
I take it you have the "premium" SE stereo? If so, keep yanking. Grab somewhere strong on it (don't grab the little vent blades). Pull up and out... maybe 30 degree angle from the straight out.
Good luck
Good luck
Use a firm, even pressure perpendicular to the screw, as if you're trying to push through the screw. Then try and applying torque at the same time. It should free up the screw. I had a little trouble too, but it shouldn't be too hard.
RealityCheck
10-02-2015 06:34 PM
