Car sluggish
Car sluggish
My car started driving sluggishly after I did a drain and refill of the ATF. I used Supertech DexronIII/Mercon.
Do you think that is the problem and should I change it to a different ATF?
The manual does state that dexronIII is a valid replacement or maybe it is the brand?
From what I understand Supertech ATF is manufactured by TEXACO or valvoline depending on which one.
I read all the threads and did not find a conclusive answer but many people said Mobil 1 Synthetic which states certified for matic d is better.
Any dex III will be fine. Check your fluid level as over or under filling can cause your symptoms.
To check:
-car and transmission must be at operating temperature
-cycle through all gears including 1, 2, 3
-find level surface
-put in park with engine running
To check:
-find level surface
If it is above the "HOT" mark you should definitely remove fluid.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
