2000 Heated seat upgrade??? among other related upgrades....
Old Aug 28, 2012 | 07:14 PM
hungy82's Avatar
Hi there folks, just curious to see if my 2k max gxe can be ugraded with heated seats, i just checked my original brochure and an option for the comfort and convenience package -which mine has- shows that you can get heated outside mirrors and heated seats only with that option. I pulled apart the center console -where the heated seat switches would normally go- and found 2 unused plugs, come to find out from schematics that those plugs are related to the heated seats.....this package also calls for a low washer fluid level warning indicator thats optional.....any ideas if it can be upgraded to heated seats???? thanks!
Old Aug 28, 2012 | 07:51 PM
gavin68's Avatar
Someone made an article on how to add the lower washer fluid level: http://www.cardomain.com/ride/259701...maxima/page-13. You have to order a sensor from Nissan. I already got one from www.nissanpartsasap.com (Tri-Cities Nissan in Johnson, TN) It would be cool to add the heated seats +mirrors. I haven't seen anything about that on here, tho.
Old Aug 29, 2012 | 05:42 PM
CaTalyst.X's Avatar
Low washer fluid level = engage washer fluid, if nothing comes out, its low.
Old Aug 30, 2012 | 07:47 AM
watut's Avatar
it's not hard to add heated seats, just time consuming. I've done it years ago with an Accord. Find a GLE or SE in the junkyard with heated seats and grab the seats and switches, then run your own wiring & relay etc.
Old Aug 30, 2012 | 10:08 AM
DennisMik's Avatar
There is no relay that has to be added for heated seats. But you might have to install fuse #9, 10 amps. Fuse 9 is in the top row, 3rd from the right.
The plug for the heated seat switch has 4 wires.
pin 1 - green/red stripe (12 volts)
pin 2 - gray
pin 3 - gray/red stripe
pin 4 - black ground)
Old Aug 30, 2012 | 12:40 PM
hungy82's Avatar
Thank you for the input on the fuse info, i couldnt find the right place to install the fuses.... As for the info on the washer fluid, really? I thought if more came out it was low....lol you missed my point, i like bells and whistles..
Old Aug 31, 2012 | 12:11 PM
noahrexion's Avatar
First thing I did on my (wifes) 00' was add heated seats for my wife. Bought a $75 CF Ebay heated seat kit and some $10 switches at local junkyard. Added #9 fuse and off we went with heated seats. No wiring relays or anything - all maximas are prewired for them.
captchaos
Mar 15, 2016 12:18 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
