2002 Maxima engine noise PLEASE HELP
Old Sep 14, 2012 | 10:30 AM
yabod4lyf3's Avatar
Ok I have a 2002 Nissan Maxima with almost 125,000, I use Shell 93 Vpower for gas. Ok well I recently have been having this engine rattling which sounds like its coming from the lower part of the engine. The noise at first was only when I turn the car off as the engine is turning off you hear a rattling noise. Now I am getting this rattling noise when I am just idling in park or neutral but goes away in drive. Also as I rev the engine to about 2000rpm when I let it go as its coming down you hear it some more. I take good care of my car Idk what could this noise be or what could have caused it anyone who has an idea or any help would be greatly appreciated thank you
Old Sep 14, 2012 | 10:53 AM
Toxic!'s Avatar
Could be your exhaust, could be anything. Can you upload a video? It will make it a bit easier to diagnose.
Nevermind the exhaust part. Just saw it does it with the car off?
Old Sep 14, 2012 | 11:27 AM
ATL's Avatar
ATL
first thought, precat rattle
Old Sep 14, 2012 | 11:29 AM
2damax's Avatar
did you ever check the heat shield by the precats. That was the cause of my rattle...well one of my rattles.
Old Sep 14, 2012 | 01:42 PM
yabod4lyf3's Avatar
um how do I upload a video for you guys to see....Video is already made
Old Sep 14, 2012 | 02:48 PM
2damax's Avatar
I usually put it on youtube and then put the link here
Old Sep 14, 2012 | 05:32 PM
DjHackStyle's Avatar
I 2nd this, and check ur oil
Old Sep 14, 2012 | 06:09 PM
Rods03Max619's Avatar
I 3rd this also....
Old Sep 14, 2012 | 07:03 PM
Toxic!'s Avatar
I 3rd this also....
I...4th this? O.o
Old Sep 14, 2012 | 08:24 PM
yabod4lyf3's Avatar
HERES THE LINK TO A VIDEO OF THE NOISES
https://www.youtube.com/watch?v=9yzd...e_gdata_player
Old Sep 14, 2012 | 09:00 PM
nishfish871's Avatar
You made the video private...make it public
Old Sep 14, 2012 | 10:26 PM
yabod4lyf3's Avatar
Try it now...it should be public now sorry about that
Old Sep 15, 2012 | 06:56 AM
StevieB's Avatar
Best guess is also, based on the video, one of your heat shields. There are several, around your front and back pre-cats just after the exhaust manifolds, as well as around your main cat, and between your exhaust and floor(unlikely to be these). You mentioned it doesn't rattle when the car is cold? As the car heats up tolerances get larger between the heat shield and retaining bolts and allow play. If one is loose, most people, myself included, just pull off the shield. The shield area around the retaining bolts rusts over time-plan B is get 2 washers (one under, one over the shield)and see if you can reinstall the shield-but be careful removing the retaining bolts or you'll break them off as they are probably rusted.
End of thesis
Old Sep 15, 2012 | 08:46 AM
ATL's Avatar
ATL
oh no, that sounds bad. i dont think that an cat. hows your oil level? u might just want to take that by a shop or 2 and get some estimates, just to see what they come up with
Old Sep 15, 2012 | 10:26 AM
yabod4lyf3's Avatar
End of thesis
But if it was one of the heat shields wouldnt it rattle while driving??
Old Sep 15, 2012 | 10:29 AM
yabod4lyf3's Avatar
I know tell me about it its stressing me out because I hope its not something too bad but idk I gotta get this figured out....and oil level is fine, oil changes are done often
Old Sep 15, 2012 | 11:31 AM
2damax's Avatar
That does not sound good. I 2nd bringing it to a shop.
Old Sep 17, 2012 | 07:03 PM
Gugs's Avatar
Sounds like a busted timing chain tensioner.
Old Sep 18, 2012 | 12:16 AM
RR5's Avatar
RR5
First guess from the 2,000 rpm rattle sound is a pre-cat with the catalyst material broken or loose inside. Remove and inspect, you'll need exhaust gaskets if you do remove the pre-cat(s).
From listening to the video it sounds pretty serious in that if it were me, the car would be on a flat bed into the shop next business day. You can pick up one of those stethoscope Poke it around the engine from the top and if you can from under the car, where you hear the noise getting louder thats the area you want to focus on.
Old Nov 21, 2012 | 11:19 AM
03blackSE's Avatar
Bumping this thread to see if OP found the cause for the sound.
I have the exact same sound, when I rev the engine in neutral as I release the gas and the rpms drop, or when I shut off the car. Doesn't rattle when I'm idling.
My oil level is good as I top it up frequently (burns about 1 quart in 3,000 miles) and I pump shell 91, sometimes Sunoco 94. Not throwing any codes either an car runs great and everything feels normal except for the rattling sound.
Question: would a loose precat make a rattling sound without throwing a code? Or does a precat failing always throw a code?
Old Nov 21, 2012 | 01:44 PM
Child_uv_KoRn's Avatar
Bad *** Newb
They do not have to throw any code. In fact, it can kill your engine and no code will ever show. Yet, (nearly) everyone thinks it's okay to leave those POS in there.
Sounds like the typical cat rattle.
Old Nov 21, 2012 | 06:07 PM
03blackSE's Avatar
Thanks.
I should've also mentioned it doesn't rattle when I'm driving around either. Seems like it's coming from the bottom of the car near the main cat; so I'm thinking its the rear pre-cat. Just ordered the O2 extenders, I'll get the pre-cats gutted as soon as they arrive.
Old Nov 21, 2012 | 06:11 PM
HotshotVQ35's Avatar
thats rod knock, need a new motor
Old Nov 21, 2012 | 07:57 PM
03blackSE's Avatar
The reason I don't think it's rod knock is because I only hear it in the above scenarios and not while I'm driving around. Would the sound not be more consistent and frequent if it was a rod knock?
Also, it's been doing this since the summer around July/August and I've been driving it around with no problems. Even did a couple 600 mile trips.
Old Nov 22, 2012 | 02:47 AM
RR5's Avatar
RR5
You can tap the cat with a hammer and listen for the rattle sound. I had the rattle noise if the engine was revved and it was gone once I replaced bank 1 pre-cat.
Now my main cat is acting up.
Old Nov 22, 2012 | 08:03 AM
03blackSE's Avatar
You replaced your pre-cat instead of gutting it? Any particular reason for that? At this point, I'd like to go with the most cost effective way possible. Wondering if it's cheaper to replace the pre-cat than paying my mechanic to gut it for me.
Old Nov 27, 2012 | 01:18 AM
RR5's Avatar
RR5
Just keeping things factory/stock. For simplicity's sake.
To gut the pre-cat you've just got to remove it, then punch out the material. Drop on some new gaskets and you are set. Do some reading on the topic so no surprises pop up.
Old Mar 8, 2013 | 08:11 PM
SAsMaxima's Avatar
Were you able to fix your problem? I've been having the exact same issue. But I also have to Code P0420, Guess I'll have to go take care of the cat. Videos:
knocking/rattle noise:
And when turning off the car:
Old Mar 9, 2013 | 05:19 PM
cmd26's Avatar
I just started having the same problem after an oil change. Havent figured it out yet damn its annoying.
Old Mar 11, 2013 | 06:27 PM
SAsMaxima's Avatar
After lifting the car, pinned the sound to the pre-cat (the bank 1 closest to the firewall). Taking pre-cat out, sure enough piece of the honeycomb mesh came out. Will be replacing the pre-cat
Got a Tread with more info: http://forums.maxima.org/5th-generat...ml#post8746565
fastcarny
May 18, 2020 10:40 AM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
