oil stabilizer
Old Sep 15, 2012 | 10:55 AM
suecer's Avatar
oil stabilizer
hello guys has any one try out oil stabilizer on they max 01. the last time i did a oil change i had 216k went for oil change today with 221k and it was very very low so the guys recommend i put oil stabilizer...Question should i on my next oil change or not....
Old Sep 15, 2012 | 12:05 PM
ateick's Avatar
Some will recommend a stabilizer like Lucas Oil Stabilizer and others will suggest a High Mileage oil to try and stop the burn. These companies have big marketing budgets and make lots of claims but the best way to find out in your particular vehicle's case is to try it and run for 3-5k and see if there is any improvement. If there isn't its not working and isn't worth the money. I have used it in an old pick up that burns oil like gas and I see a slight difference but that's just me and my particular vehicle.
Old Sep 15, 2012 | 02:52 PM
desmax98's Avatar
heard bad reviews the lucas oil stabilizer it foams up and break down the good molecules of conventional and synthetic oil so no it"s not good
Old Sep 15, 2012 | 03:11 PM
vfrpilot28's Avatar
Imho...snake oil! Just use a good quality oil and filter and skip the snake oil.
Old Sep 15, 2012 | 05:44 PM
mrjasonlyrics's Avatar
Well it's obvious you have an oil consumption issue, welcome to the club. You can do one of few things. Check your oil weekly topping it up with a thicker like like a 15W 40 not during the winter season, the 10W 30 would be better then.
You can use the stabilizer but it will only help you so much because you'll still get the oil consumption, just not as bad as when you didn't have it. I use 10W 30 and truck oil during the oil changes and I find that it's the most effective way for "me" to maintain the oil level. Other than that man there's not much you can do but top it up as it consumes. That's just the VQ's down fault
Old Sep 15, 2012 | 05:48 PM
T_Behr904's Avatar
And where did you hear this bad review information from?
Old Sep 15, 2012 | 05:54 PM
Rods03Max619's Avatar
This...Never seen it FOAM, up before....
Old Sep 15, 2012 | 07:35 PM
suecer's Avatar
thanks guys but i will stay away.....
Old Sep 18, 2012 | 10:10 PM
vfrpilot28's Avatar
I've only heard and experience positive things with Lucas products. Where is the info on the breaking down of oil??????
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
