Clutch Bleeding Procedure through mini oil pump can?
Old Dec 16, 2012 | 02:36 PM
  #41
Brl24's Avatar
Alright I've realized that I completely hijacked this thread, sorry dj.
I did try my own version of this method, I used a meat syringe with a clear hose (same typically used for bleeding). Filled the syringe, attached the hose, pushed fluid to the end of the hose, and attached that end to the bleed screw on the slave cylinder. Then open the bleed screw and push fluid up thru the system. If you have any hidden air you should see it come through the resovoir on the master, I didn't have any air so I didn't see any haha... Damn
Old Dec 16, 2012 | 05:16 PM
  #42
DjHackStyle's Avatar
Hehe no problem i juss wanted to know that this method of bleeding worked, but im going to get a SS line anyway and then try this cuz i dont wanna deal with all that hardline mess
Old Dec 16, 2012 | 07:33 PM
  #43
Brl24's Avatar
I hear that brother, the maze that is our clutch line is seriously rediclous. I'm sure there is method to the mayhem, but I don't know what it is, and I would actually like hear the pro's of that mess.
Have you sourced a ss braided full master to slave line?
Old Dec 16, 2012 | 07:56 PM
  #44
rebelhell's Avatar
http://www.racetechperformance.com/P...de=310-0154-42
$40 bucks
And as far as a reason for that madness?? My dad was an F-14 mechanic for 20 years in the Navy, he's also done a LOT of hydraulic work aside from that. He took one look at that mess and said somebody on the engineering team had a friend that needed to sell a bunch of tubing.
Old Dec 16, 2012 | 07:58 PM
  #45
Originally Posted by rebelhell
Yea thats the line i found too, gonna buy it this month and wait till spring for install
Old Dec 16, 2012 | 08:00 PM
  #46
rebelhell's Avatar
I'm planning on changing my clutch/flywheel in the spring. Figured I'd change the master/slave cylinders and that damn mess of line while I'm at it.
Old Dec 16, 2012 | 08:18 PM
  #47
Brl24's Avatar
$40 bucks
Bahaha, that's funny. Thanks for the link, I'll be ordering that soon...
And installing as soon as I receive.
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
RWCreative
Sep 21, 2015 11:01 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
Colossus
Sep 9, 2015 05:46 AM
