Performance Possibilities? Looking at 00-01 3.0
I've had a smorgasbord of vehicles from muscle, turbo imports and turbo diesel trucks. I'm looking for a Daily Driver and have always liked Maximas. I've found some clean 5 speed ones in the 3 grand range and want to know how they respond to bolt ons. Intake, Catback/test pipe and a tune is along the lines of what I'll be doing. Is it even worth it on these? I've heard on the 3.5's you don't really get much from bolt ons, but nothing about the 3.0's.
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
You are encouraged to search the forums, but as far as the 00-01 cars there are mods for them. If the car is Fed spec, they respond well to Y-pipes which eliminate both pre-cats. 01 and up are all Cali spec, so this applies to 00 cars. If you have to pass a visual inspection where you live this probably wouldn't work, unless you're crafty and can cut off and weld on a shell of a precat to the pipe to make it look legit.
I have seen the early 350z's actually loose power with simple bolt ons and want to know if it's worth my time to work on this motor or leave it as is...
I would say go to your nearest local meet and have a chat with the fellas, mebbe they'll even give you a ride, or let you drive a car so you can see for yourself.
Personally, I have a '00, all I have is a CAI and axle-back, and it's worked fine for me, precats are going out, so Y-Pipe is next...
That doesn't sound bad, I prefer the extra power that the 02-03's have over the 00-01 and its a 6-spd, you will get great miles on hwy compared to the 00-01.. Mine however burns a little oil but I stay on top of it so I don't damage anything. I have 172,ooo ml.. and runs great. $5500 isn't bad, maybe you could get it for $5000?
Yes, regardless of what you heard.....The VQ30 and VQ35 both respond well to bolt-ons! They respond to stand alone ECU's tuning if you know what you're doing...I would recommend a true CAI (like Place Racing) Ypipe or headers, a Catback and highflow cat or test pipe.....and a JWT ecu as a beginner....These cars are awesome!
Not so sure about standalone tuning, is there a piggyback for these? I've tuned some rather complicated cars using COBB race tuner and access port... Mazdaspeed 3 in particular, load based 3 dimensional tune... Made 302whp and 316wtq on my 09
I was just telling everyone what I was told about the Y pipe, whether the info I received was correct, is beyond me. I only bought the Y pipe because I got the P0420 code, I still haven't installed the pipe yet either, I don't know what I'm waiting for.
Sounds like an idea... I just found a super clean 03 Titanium 6 speed with everything I would have done to it for 5500. A little more than I was looking for but seems like the guy took care of it. He says it's not burning oil but from what I've read every VQ35 does, or is that just really common? It has 132k btw...
Crap, editing on my phone is a pain! So, part II, lol!
From what I've read, oil burning is common, but it's also hit and miss with some engines, apparently. Another apparent desirable upgrade is to swap out your stock valve covers for 6th gen valve covers, apparently it helps with the oil leaks from the valve covers. Both 5th and 5.5's have their +'s and -'s, so just go with whatever you like best. I know that I get waaaaayyyy better gas mileage with my VQ30 than I ever did with my Tacoma, which was a 3.4. On a good day, I've gotten 400 miles on 1 gas tank!
Cali Spec 2000 and 2001+ = 1 precat deleted
Fed Spec = 2 Precats deleted.
Here is the list of mods on the 03... Good deal?
Maintenance:
1. 350z Clutch
2. NGK Iridium Plugs
3. Rear Valve Cover w/ gasket
4. Every 3k oil change with Mobil 1 synthetic
5. Replaced Radiator with new.
6. Replaced all radiator hoses.
7. New Flywheel
8. KYB Struts all around
Mods:
1. 3.5" Intake w/ JWT Pop Charger
2. Block Off Plate
3. NWP Intake manifold Spacers
4. New Exedy 350z Clutch
5. New Stillen 15lb Flywheel
6. Custom 3" Bolt on Exhaust
7. 3" Test Pipe
8. 3" Vibrant Muffler
Maintenance:
1. 350z Clutch
7. New Flywheel
Mods:
2. Block Off Plate
7. 3" Test Pipe
Sorry, didn't mean to thread-jack!
Maintenance:
1. 350z Clutch
7. New Flywheel
Mods:
2. Block Off Plate
7. 3" Test Pipe
Maintenance:
1. 350z Clutch
7. New Flywheel
Mods:
2. Block Off Plate
7. 3" Test Pipe
Is it lowered? What about wheels/tires? I also say offer 5k. Do u know if the exhaust is name brand, or knockoff brand?
No not lowered, rolling stockers... Vibrant muffler and pretty sure exhaust was custom done at a shop. I feel 5500 is a little high also... Just going to wait him out and keep offering 4800, that's 100 over kbb very good private party.
That's a lot better than what I could ever get. I've seen close to 28, but in my driving, which is about 80% hwy, 20% city, I'm averaging 24 running 76 Premium. I too regularly see over 400 miles to a tank, but it's a solid 16 gallon fill.
What is this 76 premium that you are running? Also when I go 400+ miles, I'm always putting more than 16 gallons of gas in. I was just saying that 400 miles is easily obtainable.
