car is not starting
Old Oct 3, 2012 | 12:43 PM
kamui124's Avatar
car is not starting
hi guy my 2000 gle wont start, it sound like we wants but it just wont,i just replace the fuel pump, and nothing and had another post and a lot of people say that it my be the crank position sensor, or a sensor on the top ofthe gas pedal, i mean it sound like is not getting enough gas, it started just having problems i would step on the gas and everything was fine i would also hear a loud noise coming from the back of the car, but i think is totally unrelate.how can i check if the sensor just need cleaning or something else.
Old Oct 3, 2012 | 04:01 PM
DennisMik's Avatar
Did you replace the fuel pump and the car would not start immediately after that?
If the crankshaft sensors are a problem, you can try cleaning them. But cleaning is does not usually solve a sensor problem.
You need to determine if you have a no gas situation or a no spark situation. Then we can start to zero in on the cause of the problem.
If you want to down load the Nissan service manual (FSM), go to:
http://boredmder.com/FSMs/Nissan/Maxima/
However, since you have a 2000, you need to get the correct manual. There are 2.
Look at your VIN number. If the last 8 digits are equal to or higher than YT012237 or YT211681 or YT527430 or YT740492, then download the 2000.5 manual. Otherwise download the 2000 manual.
Old Oct 3, 2012 | 04:15 PM
TriniMax03's Avatar
The crank or cam sensor will throw a code, If it's one of those though the car will start after turning it over for a little while, and you can take it to get read, and you car might shut off in the middle of driving after a couple minutes but just start it back up and it should run fine until you shut it back off.
Old Oct 3, 2012 | 04:17 PM
TriniMax03's Avatar
Or it could the starter, even though it turns over still.
Old Oct 5, 2012 | 07:46 AM
kamui124's Avatar
already check the fuel lines and it getting enough fuel, sparks plugs work fine and cps works too.i have a friend check it and it say that maybe the exhaust pipe is clog up, what do u think guys
Old Oct 5, 2012 | 07:56 AM
Bassbreaker's Avatar
I think dont try to start your car if that is a possibility
Old Oct 5, 2012 | 08:35 AM
foodmanry's Avatar
Da Roller Coaster!
What was your reasoning in replacing the fuel pump? Were you having other, unrelated issues?
By chance is it is throwing any engine codes?
Old Oct 5, 2012 | 08:54 AM
kamui124's Avatar
no codes only misfire other then that no codes,
Old Oct 5, 2012 | 09:02 AM
foodmanry's Avatar
Da Roller Coaster!
A misfire code? Or car is misfiring with no codes?
Old Oct 5, 2012 | 09:31 AM
kamui124's Avatar
no codes what so ever, im really confused i dont know what to do i guess i going to take it to a shop to get ir fix
Old Oct 5, 2012 | 10:17 AM
codysmaxima101's Avatar
it could be fuel filter have u checked that yet?
Old Oct 5, 2012 | 12:39 PM
kamui124's Avatar
my reason to change the fuel pump was that went u turn the key on ON u couldnt hear working and i thought i was dead maybe it was but it seen that this wasnt the problem.
Old Oct 5, 2012 | 01:12 PM
kamui124's Avatar
how do u check the fuel filter i pulled the fuel pump and stainer, i dont know where the fuel filter is, i know is in the gas tank
Old Oct 5, 2012 | 02:04 PM
foodmanry's Avatar
Da Roller Coaster!
Fuel strainer = fuel filter in our cars. Did you replace the strainer/filter? It is hard to tell if it is good or bad. Most people replace them every so often even though Nissan says they are a lifetime part. I've replaced mine two times over 236,000 miles.
Old Oct 5, 2012 | 02:49 PM
kamui124's Avatar
yeah i replace it just in case u never know and its getting enough was, like a say im going with the exhausted because i remember that it was really loud and now i feel little air coming out of it
Old Oct 7, 2012 | 10:56 PM
MTLean's Avatar
whats the word on your starter?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
