No water draining from the A/C?
Old Oct 5, 2012 | 03:22 PM
Maxima50's Avatar
My 03 Maxima has a little musty smell to it and smells when you turn on the vent or a/c. When i run the a/c and park the car no water appears under the car. Not sure where the water is going? My carpet is all dry by the way.
Old Oct 5, 2012 | 04:28 PM
02pearlmax's Avatar
How old is your cabin air filter?
Old Oct 5, 2012 | 06:19 PM
Maxima50's Avatar
I recently replaced the cabin filters. The old ones were probably factory ones and they did stink. I cleaned out the cabin filter box and even took out the blower and cleaned it up. Still smells.
Old Oct 5, 2012 | 07:27 PM
ATL's Avatar
ATL
i believe the car only uses the cabin filter when you have the air on recirculate. vehicles usually pull their air from the windshield cowl. the openings are usually on drivers side, get a can of duct cleaner like this and spray it in the opening while you have your ac on full blast. after you feel youve sprayed enough, turn the ac off as fast as possible and let this sit in the air ducts.
Old Oct 6, 2012 | 07:05 PM
Maxima50's Avatar
I will have to look for this stuff. I guess it can be found at Autozone or one of the others?
Thanks.
Old Oct 6, 2012 | 07:30 PM
DennisMik's Avatar
This is incorrect. The air filter is after the vent door that selects outside or recirculate.
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
uttadms31
Sep 30, 2015 05:24 AM
