Spark plug gap
Old Oct 7, 2012 | 08:28 PM
shobuddy's Avatar
Spark plug gap
I'm getting replacement spark plugs for my car at Advance Auto. The recommended spark plug is this: http://shop.advanceautoparts.com/web...erm=spark+plug
The manual says to use a spark plug with a gap of .043 but this one is .044. Is this ok? It IS a PLFR5A-11 which is what the manual recommends, though I'm not sure what it means. I'm also going to replace ignition coil #4 with this one: http://shop.advanceautoparts.com/web...=ignition+coil
Is this coil legit? I see prices ranging up to $100 on Advance so should I get a more expensive one?
I'm doing all this for a P0304 SES that I was getting. Though the light is gone, I still occasionally get some hesitation so I want to take care of it.
Old Oct 7, 2012 | 09:12 PM
ShocknAwe's Avatar
plugs are what you want but that coil is crap. Only get an OEM coil which if you can get for $100 you got a good deal lol. I dont know what that code is so hopefully a 5th gen owner can help ya
Old Oct 7, 2012 | 09:53 PM
T_Behr904's Avatar
OEM coils only, and always check your spark plug gap before installing.
Old Oct 7, 2012 | 10:04 PM
shobuddy's Avatar
The manual says a gap of .043 but the Advance recommended one has a gap of .044. Will this be an issue?
Old Oct 7, 2012 | 10:12 PM
shobuddy's Avatar
The code is "cylinder 4 misfire"
Old Oct 7, 2012 | 10:39 PM
erictown's Avatar
.44 is all you can get on market. I checked the compatibility of those plugs they all anounce they can be used on our Maxima. so be it.
Old Oct 8, 2012 | 05:44 AM
foodmanry's Avatar
Da Roller Coaster!
Maybe but you can always adjust them to 0.43 with proper feeler gauges. I do this for every set I get.
Old Oct 8, 2012 | 10:18 AM
shobuddy's Avatar
What is the OEM spark plug #? I ended up going to the dealership and they gave me part #22401-5M015 but courtesy parts part # is 22401-A33B005.
I want to make sure I got the right part. The attached jpg shows what the dealership gave me.
Old Oct 8, 2012 | 11:02 AM
foodmanry's Avatar
Da Roller Coaster!
Oof...you bought OEM? How much did those cost you?
Sometimes, the part numbers are slightly different from Courtesy versus dealer (digits after the hyphen). Since the first five digits are the same, you should be good to go.
Old Oct 8, 2012 | 11:32 AM
shobuddy's Avatar
Came to about $14/per. I got the OEM mainly because I couldn't find one on the market with .043 gap (recommended in the manual). Advance was selling for about $8 each so the price difference wasn't too drastic. I'm having a shop install them.
Another follow-up. I had to put just a touch of WD-40 in the spark park cylinders yesterday because I got a ratched bit that got stuck in it. Will this do any damage? I probably put a minor scratch or two on the inside of the cylinder. Will any of these two cause any potential problems?
Old Oct 8, 2012 | 12:53 PM
foodmanry's Avatar
Da Roller Coaster!
Your price markup was 75%!!! Let me know when you need parts next time..I'll get you OEM or equivalent for much cheaper! You could have had NGK plats which is same as stock for $9 or $10 a piece saving you money and have OEM equivalent.
As I said in an earlier post you could have adjusted the spark plug gap.
To your questions...no the WD40 won't hurt anything in that location.
Old Oct 8, 2012 | 01:49 PM
shobuddy's Avatar
Thanks, I'll keep that in mind for the future. I was a bit under the gun right now as I'm taking a long trip this coming weekend and needed to do it before then. Does the price you mentioned include shipping?
Old Oct 8, 2012 | 03:04 PM
foodmanry's Avatar
Da Roller Coaster!
I was joking about me personally getting you parts...if you were under the gun that's cool, just keep it in mind for the future.
Autozone has NGK Platinum's which are OEM equivalent (same exact plugs) for $9 to $10 a piece. They usually carry them in stock so no shipping or waiting...
Old Oct 8, 2012 | 03:15 PM
Child_uv_KoRn's Avatar
Bad *** Newb
That bit of gap won't matter. Throw in NGK 1 step colder iridiums and off you go!
For about 60 bucks O_O
Old Oct 8, 2012 | 03:24 PM
ShocknAwe's Avatar
Courtesy simply lists the model after the part. TH\hat is why it says A33
Old Oct 8, 2012 | 03:27 PM
foodmanry's Avatar
Da Roller Coaster!
Difference with iridiums is they have are spec'd to last about as long as copper and definitely not as long as platinums so you really don't get the bang for your buck.
Why 1 step colder? I don't see the OP running any forced induction or nitrous.
Old Oct 8, 2012 | 03:31 PM
DjHackStyle's Avatar
do you mean u scratched the side of the wall on top of the spark plug? cause thats just a spark plug tube, wont affect anything. the actual cylinder is under the spark plug
Old Oct 8, 2012 | 09:23 PM
DennisMik's Avatar
What year is your car?
The 3.0 engines use the NGK PFR5G-11 spark plug, nissan # 22401-1P115.
The 3.5 engines use the NGK PLFR5A-11 spark plug, nissan # 22401-5M015.
Old Oct 9, 2012 | 06:26 AM
shobuddy's Avatar
The cylinder that the spark plug and coil go into. All should be well though, I had them changed yesterday and so far so good.
Old Oct 9, 2012 | 06:28 AM
shobuddy's Avatar
Its a 2003/3.5. Dealer gave me 5M015 so I got the right part
Thanks for clearing it up.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
