VQ35DE in 01 SE
Old Oct 8, 2012 | 07:28 PM
LazYRaCeR's Avatar
VQ35DE in 01 SE
Hey guys, I read up on some stuff about the Nissan Maxima and its engine, and found out that since 2002 they have been putting a VQ35DE in all maximas. Thats a 3.5L with anywhere between 255 HP and ~250 trq in a 2002, to a 280hp through 2008 and so on through until 2013 and they still put a VQ35DE in every single one just I don't know what they did to get the extra hp (enlighten us if you know) and if it changed its size and shape drastically?
My question is can I take any VQ35DE and swap it into a 2001 SE since the body styles are the same as on a 02 or 03 maxima and they have them? I would think it would be ok to do that, so long as you have the right ecu, axles, driveshaft, harness, mounts etc. has anyone done it? is is pretty easy? just wondering since I will need to change my clutch, and do a full 100k tune up on my car in the near future which requires taking out the motor anyway I just wanted to know if a swap for a newer motor is possible?
Old Oct 8, 2012 | 07:38 PM
schmellyfart's Avatar
Yup, its basically the same as swapping a vq35 into a 4th gen (95-99). Check out the all motor section and there is a bunch of 3.5 swap threads in there.
Old Oct 8, 2012 | 07:39 PM
MaxFiyah's Avatar
you can take any fwd vq35de from a fwd i believe just not a 350z or a g35 cause its rwd
Old Oct 9, 2012 | 05:23 PM
LazYRaCeR's Avatar
So it's direct bolt in? that it very good news! thanks guys!
Old Oct 9, 2012 | 05:45 PM
Max streets's Avatar
no its not as easy as drop it in u have to switch some around parts u also have to take apart half motor and thats the easy way
Old Oct 9, 2012 | 06:33 PM
TunerMaxima3000's Avatar
Clearly didn't listen to schmellyfart, you have some reading/searching in the 4th gen forums to do.
Old Oct 9, 2012 | 07:50 PM
VQ30DE-K's Avatar
You mean install 3.0 timing onto the 3.5 aka VVT delete? What if you are using 02/03 ecu?
Old Oct 10, 2012 | 03:55 PM
For 02/03 ecu u need to do a whole alot more, look at nwp's car (Aaron92se) its kinda like the same.Its not plug and play.
Old Oct 10, 2012 | 04:18 PM
Rods03Max619's Avatar
Hence the Name maybe.....
Old Oct 10, 2012 | 05:11 PM
2damax's Avatar
Really unfortunate if he does not log back on and read this thread before he starts the job!
Posted from Maxima.org App for Android
6spd4dsc
Mar 4, 2016 05:19 PM
schmellyfart
Sep 25, 2015 04:47 PM
tcb_02_max
Sep 11, 2015 12:23 PM
SilverMax_04
56
Sep 30, 2003 12:02 AM
