Noob with TCC OFF, SLIP...no ABS light
Old Oct 20, 2012 | 10:06 AM
Concealed_1911's Avatar
Just picked up my first Nissan, got it cheap figured these issues wouldnt be too hard to fix, so far no luck !
The SES, TCC OFF light, and the SLIP light stay on, the ABS light does not. Grounding DLC pin 9 flashes only a code 87 and 12. I have not been able to get it to flash engine codes with the accelerator pedal method, but the seller said it had a missfire on cyl 6 code. I have downloaded the factory service manuals, but got confused when I got to where it started talking about LAN.
I dont want o just throw parts at it, but need to getit fixed before snow here in Colorado !
Please help a noob !!
Old Oct 20, 2012 | 10:12 AM
Chuckles03SE's Avatar
Autozone, Advance and I would assume O'Reillys will pull the codes for you and tell you what it's throwing. They just won't reset the light anymore.
Old Oct 20, 2012 | 10:16 AM
After you find out what it is try searching for that actual code on here and I'm sure you'll find some info on how to fix it.
Welcome to the org btw!
Old Oct 20, 2012 | 10:34 AM
Thanks for the welcome, and the advice.
I have somesoftware on my laptop that I think will read Nissan. I will check when the car gets home and see what I find.
Old Oct 20, 2012 | 07:06 PM
Just got back from Autozone, codes are 0306, and 1320. Also stopped at Wal-mart, when we left to go home only the SES light was on, No TCC OFF or SLIP lights all the way home.
Advise me on where to go from here please.
Old Oct 24, 2012 | 08:19 PM
Ordered a new coil from rock auto, hope tha takes care of it !
Old Oct 25, 2012 | 06:22 AM
andrewmac's Avatar
Shoulda went OEM.
Old Oct 25, 2012 | 06:41 AM
It is Hitatchi, everything I have searched claim they are as good or better. Local dealer wanter more then I could afford right now for OEM, and I didnt have any luck finding any that were positivly OEM online. If it only works for 6 months at least I will know if itwas my problem, and hopefully I can spend more by then.
Old Oct 30, 2012 | 07:12 PM
Just to close this thread out for future viewers, The new coil on cyl 6 and a set of new spark plugs took care of the issue.....no more extra lights on my dash !
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
fastcarny
Oct 6, 2015 10:42 AM
Maxima30
Sep 7, 2015 06:13 PM
maximusrising
Sep 2, 2015 09:55 AM
