Lighting issues
Old Oct 31, 2012 | 10:04 AM
Professor's Avatar
Lighting issues
Problem, when headlights are on & foglights.
Issue, When i use my turn signals all my lights flash off when the turn signal is cancelled, it is only a quick blink & it has something to do with the multi function switch i believe . Does anyone have suggestions, problem solved or any other info that i can use to fix this small issue.
Old Nov 4, 2012 | 06:00 AM
gapboi210's Avatar
This seems to be an issue as our cars get older. I believe the fix is to replace the actual switch that is behind the steering wheel. Replacing the stalk portion did not work for some. Some people said theirs only flickers if the switch is in the AUTO setting.
Roymg
Sep 3, 2018 05:10 AM
trasmadean
Jan 20, 2018 05:05 AM
AnsonJ
Jun 2, 2017 01:35 PM
doctorpullit
Aug 20, 2015 05:15 PM
