Blew the Clutch Right Off the Compressor
Old Oct 31, 2012 | 08:14 PM
Galactica's Avatar
So I was driving home from trick-or-treating with my boy tonight and started hearing this mad chirping under the hood and thought maybe a belt was making noise from all the rain. Well it wasn't that.... I was about a mile from home and accelerated to about 3500 and BOOM! followed by something banging its way down the underbody. Thought for sure I threw a belt the way it sounded but everything kept right on working and I limped my way home. Only thing I noticed was my windows starting to fog up. So I pull in the garage and pop the hood and sure enough, the 2 belts are in place and there where the clutch should be is only a brass looking shaft and a free-spinning wheel.... Now I'm afraid to drive the thing for fear of the wheel falling off too because obviously that would be a little more torublesome... Am I assuming I am going to need a full compressor replacement here??
Old Oct 31, 2012 | 09:30 PM
gapboi210's Avatar
Yup
Old Oct 31, 2012 | 10:14 PM
DennisMik's Avatar
The clutch can be replaced, it is a separate service item. Most places will just want to replace the whole compressor & clutch assembly, though. Pricewise, I don't know. Higher parts cost on the one side versus higher labor costs on the other side.
But in the meantime, you could get a smaller fan belt and bypass the a/c unit. The bypass belt is 36 1/4 inches (920mm). FYI, the normal belt is 43 1/5 inches (1100mm).
Old Oct 31, 2012 | 11:15 PM
gapboi210's Avatar
12 year old vehicle, usually hard to find a clutch, I would just do a whole new compressor. Not worth the labor to just to the clutch.
Old Nov 1, 2012 | 07:12 AM
Galactica's Avatar
Thanks guys. Is this one of those parts that really needs to be Genuine Nissan, or can I get a reman from somewhere else?
Old Nov 1, 2012 | 10:59 AM
Reizy's Avatar
If the 02 is the same compressor I have one that you can pick up for $50. ~87K miles
Old Nov 1, 2012 | 11:23 AM
Galactica's Avatar
Looks like the part numbers are slightly different. They are very similar, but it looks like there is a slightly different pulley diameter and it uses a slightly different compressor, but it does look like it would mount up. Just not sure.
Old Nov 1, 2012 | 02:21 PM
Galactica's Avatar
Looks like I can get a new, not reman'ed, Calsonic compressor/clutch for around 340. Hopefully there is not any other damage to the system...
user 11122324
42
Jul 18, 2022 03:35 PM
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
pears
Sep 18, 2015 05:25 AM
