So my axle seal replacement skills.. Not so good
Old Nov 4, 2012 | 07:44 PM
webjohn's Avatar
I rebuilt my transmission and changed all the seals. I seriously screwed up the passenger side and it's leaking a lot. I bought another seal and will replace tomorrow.
Question: can I pull the axle and drain the transfer that way? Or bad idea? It's just I will most likely have to drop the cross member to get to the drain plug and forget about the position switch. So is there any reason this is a bad idea? Or can I put a nice clean bucket under the axle and then pull it out?
Thanks in advance
Old Nov 4, 2012 | 07:50 PM
Nealoc187's Avatar
SLOW
quite a bit of fluid will come out when you remove the axle, and then more will come out when you remove the seal. you'll likely make a big mess.
I've always preferred draining from the position switch.
Old Nov 4, 2012 | 08:10 PM
mtrai760's Avatar
'Trynna' is not a word
+1, just drain the transmission, your just going to make a bigger mess otherwise.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
kingw323
20
Oct 21, 2015 08:36 AM
carlosvq30
Aug 17, 2015 11:32 AM
DayHeyZeus
Garage and Workshop
Aug 16, 2015 12:29 AM
