Engine shutting off while driving
Old Nov 20, 2012 | 07:06 PM
admkl13's Avatar
I have a 2003 nissan maxima with injen cold air intake and twice now the engine shutts off and then kicks back in with in 2 to 3 seconds. I have done nothing so far since it just happened tonight on both times, can anybody help please? The car has about 204K and lately I have been noticing a rough idle when stop
Old Nov 20, 2012 | 08:41 PM
locknuts27's Avatar
SES light on?
If so take it to Advance auto to have them pull the codes. Then post it here.
Old Nov 20, 2012 | 09:19 PM
lilmoes4g63's Avatar
Check the alternator fuse on the battery terminal...
Old Nov 20, 2012 | 09:36 PM
Scottwax's Avatar
That's Mr. Detail to you
Check for codes even if the SES light isn't on, you may have a pending code. Wouldn't surprise me if it is cam sensor or IVT solenoid related.
Old Nov 21, 2012 | 03:33 AM
admkl13's Avatar
I had a po420 before but I'll go see if there are any new codes and I should add about a month ago I couldn't start the car, no lights would come on at all and I went under te hood cleaned up the battery terminals and it started fine.
Old Nov 21, 2012 | 04:35 AM
locknuts27's Avatar
I was leaning towards cam sensor myself.
Old Nov 23, 2012 | 07:44 AM
Thorzdad's Avatar
Aftermarket intake.
Engine cutting in and out.
Rough idling.
MAF in its death throes?
Old Nov 23, 2012 | 07:10 PM
IMDELL's Avatar
It can be your throttle body.... and/or idle control valve
Old Nov 23, 2012 | 07:47 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Oh, sure, it is. I bet I can make up some more parts that this car doesn't have (that are unrelated to the symptom), so I can up my post count.
Your attempt is bad and you should feel bad.
Old Nov 24, 2012 | 06:30 PM
jspagna's Avatar
^^^ That is what the issue was with my 03 Max.
Old Dec 2, 2012 | 09:34 AM
jared21927's Avatar
Mine was the alternator.....changed it a few months ago. Check the electronics on the inside of the car and see if you get a drop in power
Old Dec 3, 2012 | 07:12 PM
spock's Avatar
^^Why don't they get it??? ie parts the car doesn't have!
Old Dec 3, 2012 | 07:14 PM
spock's Avatar
Don't really think it's to up the post count. More like misinformed.
Hondarydr
Dec 30, 2024 06:15 PM
Matt93SE
May 24, 2019 02:58 PM
Justinmc760
Aug 23, 2015 03:10 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
