2000 maxima axle seals leaking
Old Nov 28, 2012 | 04:30 PM
Amoon00max's Avatar
I have an issue with my 2000 maxima leaking from both axle seal I replace with factory seals twice both sides and replace with new aftermarket axles also they already had aftermarket axles in them and it is still leaking. I can flip the dust seal lip down and it leaks from there. I am at a loss any suggestions
Old Nov 28, 2012 | 05:03 PM
036mtmax's Avatar
If your seating the axles correctly then it sounds like you may have a blown differential. Grab a hold of your axles where they go into the trans and see if they have any up and down play. If they have play and the axles and
seals are in right start looking for another tranny. I went through this last year.
Old Nov 28, 2012 | 06:13 PM
Amoon00max's Avatar
I have checked the up and down play with axles in the car no up and down movement
Old Nov 28, 2012 | 06:14 PM
Amoon00max's Avatar
I have checked the up and down movement none what's so ever that's why I am at a loss
Old Nov 28, 2012 | 09:22 PM
DennisMik's Avatar
Would it be possible for you to get some close up photos of the axle seals and axles as they are currently mounted in the car?
Old Nov 29, 2012 | 06:01 AM
Amoon00max's Avatar
Originally Posted by dennismik
would it be possible for you to get some close up photos of the axle seals and axles as they are currently mounted in the car?
yea i will try i amjust thinking that if their was up and down play it would be easy too see but that not the case and its an auto i know the manual trans seem too do it more than the auto isnt that correct
Old Nov 29, 2012 | 08:25 PM
DennisMik's Avatar
I am hoping you can take photos. There are 2 main reasons for the seal to leak - incorrect installation and the wrong seals.
kingw323
20
Oct 21, 2015 08:36 AM
acw
Aug 13, 2015 12:50 AM
jholley
Aug 11, 2015 09:38 AM
papo99
Aug 9, 2015 07:24 AM
