shaking
Old Dec 5, 2012 | 01:19 PM
uptownsamcv's Avatar
shaking
i just picked up a 02 6 speed maxima today and started to notice a problem on the way home. feels like a motor mount problem and kinda seems like a misfire. my friend has a 350z and told me that if it was a misfire i would get a engine light. engine runs smoth at idle, you cant even tell its running , it has 170,000 miles. when i floor it i feel it shaking especially at low rpm. no engine light comming on either..
Old Dec 5, 2012 | 07:22 PM
i think im going to just throw some new plugs at it first. im guessing they might be the OE plugs and were never changed out. smooth idle, just bucks when i give it a lot of throttle sometimes...
Old Dec 5, 2012 | 07:38 PM
L36's Avatar
L36
Find a hill. Put the car in 3rd and try to climb the hill while keeping rpm at 2-2.5K.
If its smooth, not ignition related, if it struggles; you got a problem.
Old Dec 5, 2012 | 07:41 PM
no hills out here. what kinda problem are you thinking?
Old Dec 5, 2012 | 08:19 PM
ImpactR's Avatar
How low of an rpm?
Old Dec 5, 2012 | 08:29 PM
T_Behr904's Avatar
Originally Posted by uptownsamcv
no hills out here.
Do the same thing going up a bridge.
Old Dec 5, 2012 | 08:43 PM
i live in central florida and its all flat out here. only hills i go up are overpasses but the closes one is 15 miles away. ill try it tomorow on my way to work..
when i test drove the car i didnt notice it, and i drove it hard. when i left the dealer i filled up at the gas station next door cause it was empty, i did use premium. about 2 lights down when i got to an area with less traffic and i got into higher gear i noticed it. than i started feeling it at higher rpms too and in 1st sometimes. it comes and goes. sometimes ill floor it and it will accelerate smooth and other times ill feel it bucking.
Old Dec 5, 2012 | 08:51 PM
T_Behr904's Avatar
Pretty much the same here in north FL, except there are bridges here in town that cross over the St. John's river.
Where in central FL are you? There are some hilly areas in the middle of the state. Back when I was in an Audi club around 13ish years ago, we took a trip to Lakeridge Winery in Clermont, and the drive there was pretty hilly. They have a lookout tower there with coin operated binoculars, and on a clear day you can see both coasts.
Old Dec 5, 2012 | 09:06 PM
i live out in poinciana. i drive through 2 over passes on my way to work , 40 miles one way. i never knew about the tower in clermont, sounds kinda neat.
Old Dec 6, 2012 | 06:25 AM
ATL's Avatar
ATL
Could be mounts, when u slam gears does it sound like ur dash is going to break off? That was most noticeable issue when I had bad mounts, the motor would jump around in engine bay if I shifted it hard. If so it's time for some polyurethane
Old Dec 6, 2012 | 06:53 AM
its not that bad. it doesnt do it till the car is warmed up pretty good. when i woke up this morning to go to the gym i didnt feel anything till the car was warmed up. its about a 10 minute drive on a 45 mph road.
this is the newest car ive ever owned. only time ive ever felt this kind of issue with my other cars it would be the spark plugs. this is also the most powerfull car ive owned so far, so i guess it would it shake harder.
i bought this car cause i always wanted a maxima since i drove my friend 95 SE 5 speed. it sucks to by a car and already have to start doing repairs. on top of that i have my CRX engine rebuilt and ready to be put back in.
Old Dec 7, 2012 | 04:44 AM
i tried the hill climb in 3rd at 2,000 rpm and it can do it smoothely as long as i dont press the gas down too much.
Old Dec 7, 2012 | 11:11 PM
user name001's Avatar
maybe you got a batch of bad gas, but i think its probably coils and within a few weeks you will get a code.
Old Dec 8, 2012 | 11:09 PM
that would realy suck. especially if i changed the plugs than have to go back and change the coils...
Old Apr 12, 2013 | 06:53 AM
thought id come back to this post, it ended up being the engine coolant temperature sensor. the car seems to run fine now.
Old Apr 12, 2013 | 01:35 PM
mist max2000's Avatar
Did you have any codes for that? How did u diagnose it to be that?
Old Apr 12, 2013 | 04:41 PM
Nismonieves's Avatar
Check to see if u have a light bulb for the MIL. bastard I bought mine from took it out
Old Apr 12, 2013 | 05:34 PM
[QUOTE=mist max2000;8770153]Did you have any codes for that? How did u diagnose it to be that?[/QUOTE
I noticed it only did it at full operating temperature
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
Bonka
Sep 14, 2015 11:18 PM
