direct fuse box grounds
Old Dec 11, 2012 | 08:35 PM
  #41
Rochester's Avatar
This isn't working out well for you, Mr. Aviator. If a person walks into a room full of strangers and gets ragged on, it's entirely possible he walked into a room full of douchbags. But if he walks into another room, and it happens again, and then yet again...
...see where I'm going with this?
damn dude learn how to multiquote.....
True enough.
Old Dec 11, 2012 | 08:42 PM
  #42
Aviation005's Avatar
Also the chassis of the car itself has a very low resistance compared to wires because the entire body shell/frame of the car is a very "fat wire" of a conductor, so grounding something in the trunk (like an amp) to the body of the car will actually be a better ground than running a ground wire all the way from the amp (in the trunk) to the battery.
the entire chassis over time rusts as do all bolts. this raises the resistance of the chassis. if you put 2 neg to chassis wires, this will lower resistance
and i dont really mind people are hating, I know it works so i enjoy everyones reaction hahhah :P guess i am half troll
Old Dec 11, 2012 | 08:46 PM
  #43
rebelhell's Avatar
Not to add fuel to the flames here, but why do you keep insisting that having TWO chassis grounds is so much MORE grounded than factory? Have you even cracked open the FSM just once? Might wanna go dust that off.
Factory Chassis Grounds
M9 - Just below driver's side A pillar
M25 - Just behind fuse box
M87 - Behind glove box
I'm glad you have TWO chassis grounds, I have THREE (3). Must be why my Maxima is so much faster than yours.
Old Dec 11, 2012 | 08:54 PM
  #44
I keep insisting because the guy above says the chassis has low resistance, this is not true.
also because i have tried with (1) 4GA wire ground, then added another and had brighter dash lights and better performance
I have tried with just the stock 4GA factory ground, the dash was dim
Old Dec 11, 2012 | 08:55 PM
  #45
Chris Gregg's Avatar
Get Off My Lawn
I'm not sure why you think Nissan is the only car company that grounds to a painted surface. I've not worked on any car/truck from 1957 to current that does otherwise. Wait, I retract that.....I worked on a Delorian that I would say grounded to unpainted surfaces.
You are right about what happens with age, and is why it is a good idea to clean those connections, bolts, and threads on the car. But grounding to a painted surface is not an indication of poor quality. You'd have better luck with that argument by mentioning our lower radiator supports.
Old Dec 11, 2012 | 09:14 PM
  #46
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by Aviation005
the chassis's resistance isnt exactly low, it all depends on the connection from the negative terminal of the battery. this is why i used 2 negative to chassis
and where exactly is the alternators ground? isnt it through the engine?
The resistance of the chassis IS low... i'm talking about the unibody of the car here. If you took the car and crushed it into a wire-like shape (after removing everything that wasn't metal) you'd find it to be a much thicker wire than any wire you were using.
And 2 grounds to the chassis isn't anything to do with the resistance of the chassis itself, which is why I said:
What you really care about here is the quality of the ground between the battery and ground, since you want the body of the car to act as an "extension" of the negative terminal of the battery.
The resistance of the wire between the battery and the chassis does NOT equal "the resistance of the chassis itself".
As for the Alternator ground... yes, but there are so many junction points along the path between the alternator bracket and the battery terminal that are not necessarily bright shiny clean metal (bolts and surfaces and whatnot), that can add resistance along the way. So bypassing the engine block and all that junk, and going straight from the alty body to the neg terminal will give you less resistance. But that's the engine we're talking about, not the "chassis".
And iirc, the alternator is connected to the engine, which is connected via a wire to the chassis at the exact same place where the battery is connected to the chassis (the wires touch, so the resistance of the chassis is irrelevant here) meaning theyou actually add the resistance of those 2 factory wires plus all junctions in between together.... to get from the alty to the neg terminal.
The chassis is just a junction for that portion of the circuit (not a conductor), and you could just as easily connect the 2 wires together floating in mid-air using a plastic nut/bolt... as long as the 2 ends of the wire touch (and as long as the chassis was grounded to the battery somewhere else).
The only things that the chassis grounds are other circuits on the car that are grounded to the chassis, such as headlights, taillights, crap under the dashboard, etc. Those actually use the chassis as a conductor rather than a junction point.
Old Dec 11, 2012 | 09:28 PM
  #47
the body would have to rust through ENTIRELY between point A and point B for this to hold true. Take a big piece of sheet metal and drill a hole through it to simulate "rust" and the resistance won't really change appreciably..
And again you are describing the resistance BETWEEN the chassis ground-point and the battery... which is a wire, or in your case, 2 larger-than-stock wires. You are NOT describing the resistance of the chassis itself (between the "chassis ground point used to connect to the battery", and "every other ground point on the chassis used by other circuits").
Give me a minute and I will draw you a beautiful picture to explain this to you.
Old Dec 11, 2012 | 09:31 PM
  #48
T_Behr904's Avatar
1.21 gigawatts
Old Dec 11, 2012 | 09:39 PM
  #49
gapboi210's Avatar
I say let him do what he is going to do. He has already made it clear on his intelligence and maturity level. Just look at the pics of the engine bay. I would keep my distance from that car but have marshmallows and chocolate handy for when it.....
Old Dec 11, 2012 | 09:45 PM
  #50
carsnwomen91's Avatar
Man, you just wasted a bunch of your life trying to explain something to this guy.
nah he just schooled him.
Old Dec 11, 2012 | 09:52 PM
  #51
T_Behr904's Avatar
Old Dec 11, 2012 | 09:57 PM
  #52
Amerikaner83's Avatar
Old Dec 11, 2012 | 10:03 PM
  #53
So when i say "the chassis has low resistance" i'm talking about R3. The resistance between two separate points on the chassis. That value will be lower than any wire you've got, assuming your connection points are nice and clean.
What you are calling the "resistance of the chassis" is R1 or R2. Those are wires, not "chassis".
So yes, reducing the resistance of those wires (by doubling them up, or making them thicker" will reduce the voltage drop across those wires, and therefore make more voltage available to the other parts of the car. If you had used a thicker wire (0 gauge) rather than doubling up the battery-to-chassis ground, you'd see the same result out a single wire though.
But that STILL has nothing to do with altering the resistance of the actual chassis (R3)... as i said twice before, you are talking about the connection BETWEEN the chassis and battery. The chassis itself is a massively big wire with massively low resistance, whether or not you can get the best use out of it a matter of what you're connecting to it, not it-itself.
And if there is paint, rust, dirt etc on your *connection points* then that's still not the "resistance of the chassis" as far as the metal in the chassis, that's just some junk you need to clean off before trying to make a connection.
Old Dec 11, 2012 | 10:07 PM
  #54
T_Behr904's Avatar
  #55
wookie, did you seriously just draw a picture?
That's awesome
Old Dec 11, 2012 | 10:11 PM
  #56
That's awesome
I happen to be awesome on a daily basis. It happens
  #57
TunerMaxima3000's Avatar
Here, I'll quote the one thing you are saying that is certainly true.
And here, I'll even praise you more, YOU'RE RIGHT ABOUT SOMETHING, but it's nothing new:
1. Stock grounds on almost all cars suck.
2. Stock grounds get worse as the car ages.
3. Replacing Stock grounds, and Adding extra grounds WILL help electrical performance, and extend the service life of all components involved.
Listen careful to the next part: This is why most guys upgrade the grounds. Some call it the 'big 3', whatever, the number doesn't matter, the purpose is to decrease the resistance to ground of the major ground points on a vehicle.
On every car the amount and location of the most vital points are different. But one thing is common, the 3 components you should be upgrading/adding grounds to:
1. Battery Negative to Chassis
2. Starter housing/Transmission Bellhousing to Chassis
3. Alternator housing/Engine block to Chassis
IMO:
- The Alternator should have it's own ground from the mounting bolt (alternator case)
- The battery negative should have 1 good 4 AWG ground that is under 14" long
- The Starter should be grounded from the mounting bolt to the Chassis with 4 AWG wire as short as possible while still allowing good routing and engine flex
- The timing case should be grounded to chassis with a 8 AWG wire. Alternatively you can run this 8 AWG wire over to the mounting point for your Alternator Ground so you don't have to run spagetti Grounds all over the bay. It will ground to chassis through the Alternators 4 AWG wire you just installed.
- Rear of engine block to chassis with 4 AWG
- Fuel pump ground to chassis (often overlooked, you do need to check the wiring diagram of your fuel pump though to make sure you can ground to chassis)
Old Dec 11, 2012 | 10:13 PM
  #58
and sorry i had to use blue for positive... did not have a red pen
Old Dec 11, 2012 | 10:15 PM
  #59
T_Behr904's Avatar
We'll forgive you...
Old Dec 11, 2012 | 10:17 PM
  #60
My point is to tell you what you should do. Anything more is overkill, but won't really hurt anything but your pocket-book, time, and the visual appearance, so long as you run the wires correctly.
My other point is that no one is saying you're wrong about your reasoning for upgrading grounds.
People are laughing because you're making outlandish, unsubstantiated claims about the results, AS WELL as doing a TERRIBLE, HIDEOUS, TEAR-JERKING job on your wiring.
Anyone with any competence is shaking their head profusely at your pictures.
The claims, no fuse, and all the other idiocy is just amplifying the ridicule.
Swallow your pride, eat some ****ing humble pie, and accept that you do not know much of anything about this stuff, despite what you think.
Only then might you actually be able to learn something. Because right now your head is far too enlarged with mis-information for any good, truthful info to get in.
  #61
Rods03Max619's Avatar
Old Dec 11, 2012 | 10:18 PM
  #62
The surface resistance of the ground-point will get worse over time due to corrosion/grime etc, but the point-to-point resistance within the metal skin of the car should stay close enough to the same that it should never be noticeable. Unless all of the metal surrounding that particular ground point starts rotting away, then you have a problem.
Barring that, as long as you clean it up good and use something to help ward off future corrosion/dirt (dielectric grease or something) then the grounding point should perform admirably for years to come.
Old Dec 11, 2012 | 10:20 PM
  #63
this muhfukka drew the muhfukka a muhfukking picture
Old Dec 11, 2012 | 10:23 PM
  #64
Dude is just really confused about the whole thing.
I think he learnt 1 very, very, very simple thing about electricity, and now he thinks he knows everything.
We've all been there, it takes knowledge to step back and decide to
A) learn more or B) Do not profess to know anything
Either way, you will NEVER know it all. There will always be a guy who knows more, and just when you think you've wow'd everyone listening to your big INTERNET POST, someone smarter will come in and make you look like a moron.
  #65
T_Behr904's Avatar
Well, bedtime for me. Looking forward to checking this thread out tomorrow to see what comes of it.
Old Dec 11, 2012 | 10:24 PM
  #66
T_Behr904's Avatar
Old Dec 11, 2012 | 10:25 PM
  #67
Currently Active Users Viewing This Thread: 11 (7 members and 4 guests)
TunerMaxima3000, Amerikaner83, CapedCadaver, jd87sep, rebelhell, SandyMax96, T_Behr904+
Old Dec 11, 2012 | 10:28 PM
  #68
rebelhell's Avatar
Many resistors and conductors have a uniform cross section with a uniform flow of electric current and are made of one material. In this case, the electrical resistivity ρ is defined as:
P=R(A/L)
where R is the electrical resistance of a uniform specimen of the material (measured in ohms, Ω) L is the length of the piece of material (measured in meters, m) A is the cross-sectional area of the specimen (measured in square meters, m²). The reason resistivity is defined this way is that it makes resistivity a material property, unlike resistance. All copper wires, irrespective of their shape and size, have approximately the same resistivity, but a long, thin copper wire has a much larger resistance than a thick, short copper wire. Every material has its own characteristic resistivity—for example rubber's resistivity is far larger than copper's.
In a hydraulic analogy, passing current through a high-resistivity material is like pushing water through a pipe full of sand, while passing current through a low-resistivity material is like pushing water through an empty pipe. If the pipes are the same size and shape, the pipe full of sand has higher resistance to flow. But resistance is not solely determined by the presence or absence of sand; it also depends on how wide the pipe is (it is harder to push water through a skinny pipe than a wide one) and how long it is (it is harder to push water through a long pipe than a short one.)
This is why the extremely large steel conductor of the chassis has such a high conductivity when compared to the copper wire. Even though copper is a better conductor given all else being equal. (Copper's conductivity is about 5.96×107 σ (Siemens per Meter) where as steel is about 2.17×106 σ (S/m))
If you don't believe me, go ahead and buy a meter to measure it yourself. Just take whatever resistance readings you get and find the inverse. That will be your measurement in Siemens. (Although I am quite sure that anything you can afford or even have access to will not find any difference in resistance between the two. Most instruments will just read 0Ω)
Old Dec 11, 2012 | 10:34 PM
  #69
Mfkr still couldn't answer my bonus question
Bonus question: How many amps are flowing through R2? Through R1?
How many watts for R2? And R1?
Old Dec 11, 2012 | 10:37 PM
  #70
Ahhh I just got trolled going back to look to see if you actually posted that question
Old Dec 11, 2012 | 10:38 PM
  #71
In for the people trying to do the 'bonus question' right now
I'm not trying, if that's a good hint for anyone scratching their head.
Old Dec 11, 2012 | 10:39 PM
  #72
P=R(A/L)
wall 'o text!
yeah that's what i meant by taking the whole metal body of the car and crushing it into a wire-like shape. Or melting it, then drawing it out into a wire that was the same length as the car, and whatever cross-section that same amount of steel would happen to become when extruded to its original length (i'd imagine several inches thick??).
Heck if you know the density of steel and the weight of the car's unpainted bodyshell, and the length of "steel wire" that would match the length of the car, you could probably figure this out pretty quickly... How many cubic centimeters worth of metal is in the car's body... and what does that turn out to be in a cylindrical shape of a known length?
  #73
Mr. Brett's Avatar
Ooo! Ooo! I want in!
Old Dec 11, 2012 | 10:40 PM
  #74
Also: The alternator DOES have it's own dedicated ground. It's achieved off a crappy bracket that mounts to the alternator.
Once of the first points you should fix.
Old Dec 11, 2012 | 10:41 PM
  #75
jd87sep's Avatar
Old Dec 11, 2012 | 10:42 PM
  #76
So let's put this into this simple voltage divider. Vin is 12v, Vout is what we are looking for. R1 is 1Ω and R2 is 3Ω.
Vout = Vin ( R2 / (R1 + R2))
9v = 12v * (3 / (1 + 3))
9v = 12v * (3 / 4)
It's there
  #77
Mr. Brett's Avatar
Since this thread is already derailed, here's a serious question for the wookie:
I have some 4 Ohm tweeters I want to run in line with my factory tweeters to add a little more clarity to the factory Blows system. I know the Bose system is 2 Ohms, though. How do I drop resistance in the aftermarket tweeters to 2 Ohms? Splice in a 2 Ohm resistor...?
I sound like a n00b. But I only know basic electrical concepts.
Old Dec 11, 2012 | 10:44 PM
  #78
rebelhell's Avatar
It's late and a very long time since I've used the equations but I'll give it a stab.
R1=3A W=9
R2=3A W=27
Did I win the cookie?
Old Dec 11, 2012 | 10:45 PM
  #79
a wire? or just a ground path through the metal bracket, engine block and eventually to the chassis-to-engine groundwire? I've only worked on a VG maxima before (electrically) so i don't know where the engine-to-chassis ground is on a 4th gen or 5th gen. On the 3rd gen VG motor it's on the coolant return tube from the radiator to the waterpump.
Old Dec 11, 2012 | 10:48 PM
  #80
Buy new speakers
the resistance that matters (sound wise) is the resistance of the coil. Jumping around the coil with a resistor will double the amperage draw of the whole assembly (ie, might make the amp do more work as if you had 2Ω speakers attached), but it won't increase the draw through the coil, but it won't net you more sound (and might screw your existing sound up), so if you want a 2Ω speaker, buy a 2Ω speaker.
http://www.bcae1.com/spkrmlti.htm
