ABS/TCS Off/Slip light all on
I have a 2002 Maxima with all three of these lights on. So, I did a thorough search here and ran the self diagnostic by grounding PIN 9, thinking I would get the code for a problematic wheel/ABS sensor. Instead, I received code 71 - Control Unit BR-72.
I have no idea which control unit that is. Can anyone assist me in troubleshooting???
EDIT: Couple other things to add about this issue:
1) This only happens when ambient air temperature is below 60 degrees and engine is cold. Once engine has warmed up, I can restart engine and all the lights go off
2) Speedometer doesn't work when lights are on and goes away when lights are all off
It sounds like you found the ABS control unit. But to back up to your original post, you had code 71. The BR-72 is the FSM section and page number to look at for troubleshooting. Section BR is Brakes. Page 72 has the diagnostics for code 71. Did you try this?
The thing I find most odd about this particular issue is that it only happens on a cold engine when the outside air temperature is below 60 degrees. Even on a frigid day, once the engine is warm, I can just restart the car and it goes away until I have a cold engine again.
I am considering selling this car as is without fixing this. After repairing MAF, replacing struts, brakes, alternator, etc all by myself, I am really tired of keeping up with this car.
Thanks. I am looking at the FSM and BR-71 puts me in the middle of a procedure which seems odd. Any idea where the ABS actuator is located?
The reason I use the 2001 FSM for this is that it has the most information on ABS and even then it is kind of pathetic. Get the 2001 FSM BR section from here and you can follow it.
http://boredmder.com/FSMs/Nissan/Maxima/2001
Basically, the diagnostic procedure has you check that the ABS control unit is grounded via pin 16 of the connector. Then you check for 12 volts on pin 17 of the control unit when the ignition switch is on. If those 2 pins check OK, then the control unit is bad.
The control unit is on the top of the ABS assembly that is under the master cylinder. What I am not sure of is where the electrical connector is to do these tests. I can't see it from the top. It is kind of a big connector with 30 wires in it split into 2 rows.
Thanks for the info, DennisMik. I'll tinker around with the diagnostics and see what I can figure out. I still think it looks like a big procedure to replace the control unit if it is bad. Car has 142k miles on it, so I want to spend as little as possible on this repair.
UPDATE
So, something I forgot to mention was the laundry list of CELs at same time, U1001, P1574 x 2, and P1212. After combing this site, I finally found the thread I was looking for:
https://maxima.org/showthread.php?t=652640
Definitely a failed ABS control module.
Now off to the three other major problems - the ridiculously hard shift from 1st to 2nd, the world's periodically loudest heater A/C, and the no heat while idling issue.
Yes that is definitely the issue... replace the module and you be set... its a big giant pain in the *** to get to though. Make sure you have the tools both I and paradiddle mention!!! Have fun and good luck
Brudface, Any pointers you can give to simplify? I would really appreciate any pointers you can give.
channoff
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
