Keyless entry doesn't work
Old Dec 10, 2012 | 10:13 PM
mrnando's Avatar
I'm having a problem with my 2001 Nissan Maxima. My remote, interior lights, truck release don't work when the car isn't on. I have a manual, but I can't locate the circuit breaker between the fuse link and the smart entrance control unit. Any help would be appreciated.
Old Dec 10, 2012 | 11:13 PM
dfj240's Avatar
Hmmm... Does the remote work at all when the car is on? If not, it may just be your remote.
As far as the circuit breaker location, go to www.nicoclub.com/fsm/maxima/2001/el.pdf and check out page el-354. At the bottom of the page it shows it behind the fuse box near the combination flasher unit. I'd imagine it's probably pretty tough to locate in the car itself, but that will give you a good guideline for where to look.
Anyways, hope that helps, beyond that I will yield to the expertise of others on here. Lol.
-Nathan
Old Dec 11, 2012 | 09:12 AM
mrnando's Avatar
Yes, the door locks, trunk release and remote work when the car is on. That's why I'm thinking some is wrong with either the fuse link or circuit breaker. Could the Smart Entrance control Unit be bad too if works when the car is on?
Old Dec 11, 2012 | 12:39 PM
DennisMik's Avatar
Since the items work with the car is on, then the fuse/circuit breaker is good. A fuse/circuit breaker cannot be bad when the car is off and fix itself while the car is on.
I'm not sure what the problem is but try unplugging the connectors on the SECU and then plugging them back in. I might help.
Old Dec 12, 2012 | 09:59 AM
dfj240's Avatar
Yea, he's spot on, if it was the circuit breaker or a fuse it wouldn't work at all, car on or not. It honestly, could just be the remote battery, or the remote itself, but unplugging the SECU, cleaning the contacts, and plugging it back in could sort it out.
-Nathan
Old Dec 18, 2012 | 01:12 PM
mrnando's Avatar
Could the SECU be bad? the interior lights don't work at all, door open or on.
Old Dec 18, 2012 | 03:49 PM
DjHackStyle's Avatar
Checked the bulbs and fuse?
Old Dec 18, 2012 | 04:05 PM
mrnando's Avatar
Yes, I replaced the fuse and bulbs are fine.
Old Dec 19, 2012 | 08:01 AM
Aviation005's Avatar
bad ground
check your battery and cables for corrosion
ah2002
Mar 9, 2016 01:42 PM
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
cstrasz
Aug 27, 2015 08:07 AM
Flores94
Aug 13, 2015 01:17 PM
