driving lights
Old Dec 19, 2012 | 08:15 AM
jeepdude87yj's Avatar
driving lights
does anyone know of a driving light that you can actually see other than the stock bulb or lens? mine is useless and can't see anything with it on a 2000 maxima. does a brighter bulb work? thx
Old Dec 19, 2012 | 09:41 AM
Prophecy99's Avatar
do some more searching, and yes a brighter bulb like a PIAA or Sylvania Silver Star Ultras replacements would definitely be better. also check your 10 year old headlights for oxidation and wear. If they are foggy and yellow you should restore them since all the cloudiness is ruining the brightness & output also.
Old Dec 19, 2012 | 04:04 PM
I have newer lenses, not foggy. but not sure if anyone has bought some better ones that made a difference?
Old Dec 19, 2012 | 04:11 PM
T_Behr904's Avatar
Don't forget to check the headlight aim. Too low or too high can affect the beam pattern on the road quite a bit.
Old Dec 19, 2012 | 06:17 PM
maxlover99's Avatar
I have Maxima 99 with stock light bulb working after 11 years and started changed to Sylvania Silverstar Ultra. They worked much brighter for sure, but also cost me a lot more:
$49.99+tax -$10 (MIR) from Peppboy. The only problem is that after about 12 months, both went out. I have to switch back to stock type as they are way more reliable. Now on ebay, Silverstar Ultra is getting cheaper now $24.99 free shipping:http://www.ebay.com/itm/Sylvania-Sil...aaaa88&vxp=mtr
Old Dec 19, 2012 | 06:31 PM
tigersharkdude's Avatar
OP, did you purchase your new headlight housings off of ebay??
Oh and.......projector retrofit or BUST
Old Dec 22, 2012 | 02:08 PM
CMax03's Avatar
I have OEM HID w/upgraded bulbs and treated headlight lenseI did 1 time 2 years ago and they still look new....I also run HID Foglights .....Having Oem lights is an advantage over anything sold aftermarket period!
Old Dec 22, 2012 | 02:34 PM
CMax03's Avatar
I love HID for this reason here....Less heat than high output halogens which also require use of high temp connectors....Advice from the wise PIAA are expensive and don't outperform $15 JcWhitney bulbs....That was tested by myself folks....Invest into an Oem headlight and treat with Lightbrite....and adjust aim!
Old Dec 22, 2012 | 03:27 PM
HID projector Retro>OEM reflectors
tsi6001
Oct 3, 2022 10:23 PM
kjlouis
Nov 24, 2018 06:09 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
yat70458
Aug 3, 2015 01:16 PM
