$200 What to do??
Old Dec 26, 2012 | 06:10 PM
  #121
Grand_hustle17's Avatar
Originally Posted by Max_Gator
I didn't read everything so not sure if someone said it: Don't go with springs.
It will cost you far more than $200 to do them properly.
To do springs correctly, you are going to need to upgrade your struts, get an alignment and likely camber bolts or a kit to get the alignment correct.
The reason you will need those things is that the springs are shorter and stiffer than stock.
You will need an alignment after changing springs ($60-$80 unless you already have a lifetime somewhere). If you don't do that, you are asking for quick tire wear and the cost of purchasing new tires sooner.
More than likely, camber won't be able to be set properly because of the different geometry, you will need to buy camber bolts or a kit and have it installed ($60-$80) to get it aligned properly.
And, the stiffness of the springs needs to be compensated with better struts. So, you either need to buy new struts or the stiffer springs will kill your current struts. Especially if they have a bunch of miles on them. Are you currently driving on the original struts? If so, they will die a quick death.
In other words, your $200 mod will end up costing you lots more money.
Since you don't like the RSB, I would suggest a true cold air intake like the place racing version. You do have to cut a hole in the fender but really, it is no big deal. It will give you a power boost, sound a little better, and look very cool to your friends when you show them under the hood! You will also be able to say "my intake is better than yours" because it is a cold air intake. I'm just not sure that it is less than $200. Probably can find a used one.
Looking at your sig, I gotta say im extreeeeeeeeeeemely excited to hit the track next season lmao..... was there any weight reduction done running those times???
Old Dec 26, 2012 | 06:19 PM
  #122
nismopc's Avatar
bet you don't have headers lol
You betcha I don't...
...this is just perfect for me and the kids
[but my y-pipe has been sitting in the garage for a while getting lonely]
Old Dec 26, 2012 | 06:37 PM
  #123
flyan's Avatar
If I were you, I would most definitely start with the lowering springs. I would go with H&R's though. Check out shiftice's website and look at the spring comparisons that he makes before you make a decision.
You're gonna need the change for the alignment. Good luck!
__________________
Old Dec 26, 2012 | 08:10 PM
  #124
tosheto's Avatar
Stillen front lip:
http://www.stillen.com/product/body-...8271-1246.html
Old Dec 26, 2012 | 09:06 PM
  #125
DjHackStyle's Avatar
OK i read all 4 pages, im tired. now ive been in your shoes and ive learned over the last few years, modding is 2nd to maintenance. so if you've got the maintenance covered then you can mod. and my opinion is you should get a y pipe or a SRI.
but i think you'll be happy with an intake. i know i was. i also got a set of springs (eibach) for the time being i didnt change anything else and im feeling it now, i will have to change everything soon, so dont do that.
Old Dec 26, 2012 | 10:29 PM
  #126
Finchum's Avatar
oh to be 16 again...it's funny reading all the 'been there-done that' posts from the other guys that are thinking like me. But, you live and learn. And the journey is apart of the fun, no matter how much money is blown.
(1) I recommend used springs from the classifieds-H&R's or tien H-techs will work best with the factory struts (guaranteed to go out in a year if they are super old) ~$150 shipped and immediate appreciation from others for the looks
(2) Ghetto airbox mod-drill 1/4" holes in the face of the airbox to get the intake sound and achieve gains close to a basic short-ram. $Free. go for about 6 holes in the middle front ( also removed the front crankcase vent hose 'baffle' and replaced with a straight section of spectre autozone intake pipe/coupler)
(3) if you have buddies with mechanical aptitude towards working on old cars that break bolts, gut your precats for a big bump in power. Use spark plug anti-foulers on the rear o2's to trick the ecu into thinking the precats are still there. ~$10. a little growl added at idle.
Good luck with your endeavors with the Maxima. Its definitely a nice car to have starting out in the car game.
Old Dec 27, 2012 | 12:55 AM
  #127
tosheto's Avatar
I think he already has GAB
Old Dec 27, 2012 | 06:36 AM
  #128
Max_Gator's Avatar
Took out the spare tire, that's it.
Slipped the clutch from about 5000 rpms.
It was a cold morning (by Florida standards) and that time was a one off for me. Pretty consistently ran 14.5s. One of my friends at the time ran a 14.34 stock in an almost identical car but his was definitely quicker than mine stock and he could drive better... lol.
Old Dec 27, 2012 | 07:34 AM
  #129
TallTom's Avatar
Since you live in TX, I would just invest in some good 15-20% window tint.
Old Dec 27, 2012 | 08:40 AM
  #130
Rcrootbeer's Avatar
Wow I thought this thread was going to the graveyard hahah. Well lets see, I already have tint, and the GAB. I was unaware that if you put the OEM muffler on the catback it will get rid of all the sound. Andd I think I have the original struts/shocks at 93k so springs might not be a good idea because I dont have 500 bucks for struts. I still havent made a decision, so this is all valid info. Thanks for keeping it going!
Old Dec 27, 2012 | 09:52 AM
  #131
cjandura's Avatar
I vote do a complete maintance and upgrade.and throw in some ES bushings and moog joints then do some LED mods the easy stuff
Old Dec 27, 2012 | 10:07 AM
  #132
95VQ30's Avatar
get 400 tacos at Jack in the Box
Old Dec 27, 2012 | 10:55 AM
  #133
Amerikaner83's Avatar
See my sig lol
Old Dec 27, 2012 | 11:28 AM
  #134
cjandura's Avatar
See my sig lol
Shamless advertising
Old Dec 27, 2012 | 11:38 AM
  #135
Rochester's Avatar
Assuming rootbeer is still running on original equipment tie-rod ends, ball-joints, end-links, wheel bearings, and all the various bushings throughout the car... then absolutely some preventative maintenance would make his car feel tight and reborn.
But CJ, the kid is 16 with $200 burning a hole in his pocket. Let him buy a toy, for crying out loud. Plenty of time for maintenance after parts break.
Old Dec 27, 2012 | 11:45 AM
  #136
cjandura's Avatar
I like to fix before it breaks
Old Dec 27, 2012 | 11:59 AM
  #137
always
Old Dec 27, 2012 | 12:52 PM
  #138
Rcrootbeer's Avatar
When I first bought the car I changed the rotors and brake pads, and I noticed some more wear so I replaced the tie rod ends, and CV axles. But yes, maintenance before mods is important.
Old Dec 28, 2012 | 04:22 AM
  #139
Those are pretty sweet times man... You rarely see anyone with DEK's that actually run em... Looking at your mod list im kinda excited to run mines next season just to see... Only power mod i see different from me is the midpipe.... Were you tuned?
Old Dec 28, 2012 | 06:26 AM
  #140
TunerMaxima3000's Avatar
I approve of this post
Old Dec 28, 2012 | 10:20 PM
  #141
zzmmrx0xmzz's Avatar
Lowering springs for your budget! Helps the look and handling!
Old Dec 29, 2012 | 01:17 AM
  #142
Car looks sexy^^^^^
Old Dec 29, 2012 | 01:45 AM
  #143
atxking27's Avatar
/thread
Old Dec 29, 2012 | 04:37 AM
  #144
mrjasonlyrics's Avatar
Did it cost you $200 to lower your car? Lowering springs+ camber kit+ labour+ alignment won't add up to $200. Anyone who say lower your car with just springs is giving you bad advice. Lowering on stock shocks/struts will have a back lash which is your shocks/struts will have you bouncing around in months, no camber will cost you new tires in about the same time, and no alignment will cost uneven wear and tear on your tires.
If you only have $200 to invest take the money and treat your girl out to dinner, that will benefit you more...
Old Dec 29, 2012 | 06:07 AM
  #145
Max_Gator's Avatar
Nope.
The key is slipping the clutch. Takes practice and wears out your clutch!
Old Dec 29, 2012 | 12:35 PM
  #146
Labour, struts, front strut mounts. Yup. All good calls.
You can save money doing it yourself, but without either a good vice, or an air-impact, it's not really possible.
You can skip the front mounts, but you'll just be paying to pull it all apart again in short time.
Camber kit? No, not really needed.
All in all, there's really no reasonable way to do this even half-way properly for under $300-400.
And to lower your car for $400 is a smoking deal. To think you're going to do it for $200 is asinine. You may as well just heat a bloody spring up.
  #147
Nope.
Oh im sure lol... Now im def going to the track when it opens lol ... Ever dynoed?
Old Dec 29, 2012 | 12:57 PM
  #148
T_Behr904's Avatar
Good point. Might as well save up for coilover's.
Old Dec 29, 2012 | 01:08 PM
  #149
Shift_A32B's Avatar
$200...RSB or a used y-pipe would suffice...but since you don't want either one of those, just save the $200 for something better.
Old Dec 29, 2012 | 02:39 PM
  #150
Rcrootbeer's Avatar
So, here's an update. I was going through the car wash and it ripped my rear bumper off completely. Like totally off. Im getting a refund, a new bumper, and MORE MONEY. Best 3 dollars I ever spent...
Old Dec 29, 2012 | 02:46 PM
  #151
T_Behr904's Avatar
That shouldn't have happened. The previous owner of your car must have had rear end damage and halfazzed putting it back on.
Consider yourself lucky you're getting something out of it. Car washes usually have signs posted up that they are not responsible for damage.
Old Dec 29, 2012 | 02:56 PM
  #152
^^This. I'm shocked they're reimbursing you. There's usually signs saying they are not responsible for any damages that may be caused during the wash cycle. You better tell everyone where that car was is so that they can get a new bumper or so.
Old Dec 29, 2012 | 04:31 PM
  #153
Rcrootbeer's Avatar
Hahah well even if it did have signs that's like putting a sign on my car saying "If I wreck into you and total your car its not my fault and there's nothing you can do about it." I mean seriously...
Old Dec 29, 2012 | 04:47 PM
  #154
T_Behr904's Avatar
You're missing the point. Most places aren't responsible for your vehicle. Repair shops and dealerships are the same way. If someone hops the fence, busts out your window and steals your stereo, they aren't responsible for paying for it. You got lucky the place you took your car to get washed is reimbursing you for the damage.
Old Dec 29, 2012 | 04:58 PM
  #155
Yeah, your insurance may cover it, but it is CRAZY rare that the place you took it to is paying for it.
Strange.
Old Dec 29, 2012 | 05:25 PM
  #156
T_Behr904's Avatar
Strange.
The place must have a n00b manager or something... either way, I'd take the money with the quickness and run before he wises up to company policy
Old Dec 29, 2012 | 05:30 PM
  #157
I have had my foglight cracked from the water on the hot lense, antenna broken off, and my wiper arm ripped off and got nothing back. A touchless car wash have a no obligation policy and they are not liable for anything that happens when your car comes out on the other end. A car wash is a few bucks and if a part of your car is installed incorrectly or unsafe chances are it will break off. If they reimburse every car that comes out with a damage a car wash will never make money.
Consider yourself lucky that they did because they don't have too nor can you sue them or file some sought of complain. Bet you it won't work again
Old Dec 29, 2012 | 05:44 PM
  #158
again..... Ebay catback $100 and cosmo pulley $81 shipped....... seems ive offered the best option for your $200... seeing as though you hardly mod and just about every thing outside of $200 buck right now seems out the budget, then ebay catback and pulley should be a nice upgrade
Old Dec 29, 2012 | 05:47 PM
  #159
Rcrootbeer's Avatar
Im considering myself lucky as of now.
Old Dec 29, 2012 | 06:07 PM
  #160
who cares, you're selling the car, right?
