oil leak behind pulley above oil pan area
Old Jan 8, 2013 | 07:28 AM
tufan's Avatar
cleaned the entire area. appears oil is coming from a seal near the large pulley that is located above the oil pan.
here are some pics of the area. looking for repair information.
Attached Thumbnails oil leak behind pulley above oil pan area-img_0576.jpg   oil leak behind pulley above oil pan area-img_0578.jpg   oil leak behind pulley above oil pan area-img_0580.jpg   oil leak behind pulley above oil pan area-img_0585.jpg
Old Jan 8, 2013 | 07:34 AM
foodmanry's Avatar
Da Roller Coaster!
Do a search...I'm assuming you have a 2k2 or 2k3? These model years have been known to leak in that area. There is a lot of information on how to fix it.
Old Jan 8, 2013 | 07:38 AM
tufan's Avatar
ok, will do search
it is a 2000 model
Old Jan 8, 2013 | 07:40 AM
foodmanry's Avatar
Da Roller Coaster!
In that case...likely your front main seal.
If you want specific repair information you can do a search for that on here, or you can consult the FSM in the link below.
http://boredmder.com/FSMs/Nissan/Maxima/2000/
You would look under the EM section.
Old Jan 8, 2013 | 07:59 AM
tufan's Avatar
ok thanks for the help. i will take a look at the file and then get under the car and take another look based on this info. thanks for the help.
Old Jan 8, 2013 | 09:49 AM
Prophecy99's Avatar
http://forums.maxima.org/5th-generat...oler-base.html
that might help
Old Jan 8, 2013 | 10:49 AM
foodmanry's Avatar
Da Roller Coaster!
That was what I was originally referring to, but 2k and 2k1 do not have the o-ring. The o-ring is specific to 2k2 and 2k3 model years.
Old Feb 22, 2013 | 06:12 AM
ffcbairn's Avatar
foodmanry do you know the part number of that seal?
Edit: 13510-31U10 is the latest part number, 13510-31U00 was the previous part number which some places might still stock.
Old Feb 22, 2013 | 07:44 AM
Max_Gator's Avatar
I believe there is a drain plug behind the pulley that tends to leak. Search around.
Old Feb 22, 2013 | 07:48 AM
NmexMAX's Avatar
dot dot dot ...
Yes, search, the answer is out there. And you'll get conditioned to searching.
kjlouis
Oct 3, 2015 05:29 AM
The Wizard
24
Oct 1, 2015 08:47 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ag90fox
Sep 9, 2015 12:22 PM
