SEEKING ADVICE: 5.5 gen coilpacks vs. M35 coil packs
Old Jan 12, 2013 | 06:35 PM
nishansMaxima's Avatar
well i was at the junkyard and was looking for some coil packs to get for my 5.5 gen. didnt come across any of my year but i did come across a 07 M35. The coils looked the same as the 5.5 gen. My question is, is there a difference between the two? Ive tried to do some research on this but couldnt find anyone who tried this. Maby some one did and never posted about it.
Anyway..as far as i can tell physically..the m35 is a tad bit taller..and the number on all of them end in 3103g and the 5.5 gen end in 3102g. Anything different with voltage wise??
Old Jan 12, 2013 | 06:42 PM
quick-e's Avatar
I am not sure of the exact difference but there is a difference. Even the look is different in the middle of the stems and the height distance I would trust. That is a lot of work to install them for them not to work properly. If you are feeling lucky you could always swap out the front three which are ez and see if you have an issue. Again remember they get mounted in if one is taller will it allow you to mount properly? Just a few questions I would have. Good luck bro.
Old Jan 13, 2013 | 04:26 PM
can anyone else chime in on this please?
Old Jan 13, 2013 | 04:45 PM
DjHackStyle's Avatar
I think the stem can be swapped, try that. Sorry in advanced if i made you break it lolz
Old Jan 13, 2013 | 04:50 PM
im not worried about the stem length..im more concerned about the voltage to the plugs
Old Jan 15, 2013 | 11:08 AM
NmexMAX's Avatar
dot dot dot ...
Aside from the length, they will be the same.
The length differs due to the IM design on the RWD VQ35. Considering the price on FWD coil packs these days, why not just go with those? Nothing to gain using the M35 units.
Old Jan 15, 2013 | 03:18 PM
cool thanks bro!
Old Jan 15, 2013 | 04:21 PM
Unklejoe's Avatar
They will work even without swapping stems
MAXSE5SPD
Sep 17, 2022 04:00 AM
crazyespn
Sep 3, 2015 01:30 PM
