Oil cooler leaking???
Old Jan 19, 2013 | 06:29 PM
blocster's Avatar
I believe my oil cooler is leaking on my 02 Max. I was wondering if anyone has had this problem and if it fixable without replacing...
Old Jan 19, 2013 | 06:52 PM
koreanthunda's Avatar
Check the hoses for leaks first with a thorough cleaning then dry well then run and look.
Old Jan 19, 2013 | 06:55 PM
cjandura's Avatar
Is it oil or antifreeze
Old Jan 19, 2013 | 07:27 PM
DennisMik's Avatar
If you check all the other things that have been suggested and you still beleive that it is the oil cooler, you probably need new o-rings that go between the block and the oil cooler adapter.
Old Jan 19, 2013 | 09:37 PM
Chris Gregg's Avatar
Get Off My Lawn
^^______ Plus one. Although its indicated that there's only supposed to be one, Nissan actually lists two that are slightly different sizes..... So one would fit inside the other. Not knowing which I needed, I just bought both. Once I pulled my oil cooler off, I realized both would fit. Since I had read mention that even after replacing the one o-ring some experinced a recurrent leak down the road, I decided to use both the o-ring gaskets with just a smidge of black silicone. Dry as a bone since! And given both gaskets together were less than $15, why not for the peice of mind!?
Old Jan 20, 2013 | 05:06 AM
Aviation005's Avatar
just had my oil cooler GASKET replaced. it will look like a leak coming from the oil filter.. since the filer bolts onto the cooler
took 5 minutes to replace. dont let a mechanic rape you
Old Jan 21, 2013 | 09:37 AM
Prophecy99's Avatar
this ! its a good chance it is you're o-ring.
right behind the oil filter !
search its a common leak
Old Jan 21, 2013 | 01:51 PM
03VQMAX's Avatar
I had that leak a couple weeks ago, searched the complete parts list and FSM and COULD NOT find the O-ring or it's part number anywhere?? Regardless, I had tighten the filter too much, so it's not leaking anymore, I guess it had to much pressure.
Old Jan 21, 2013 | 06:03 PM
backccopy's Avatar
i agree it,you probably need new o-rings that go between the block and the oil cooler adapter.
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
