Would Struts Usually Be Considered A Maintenance Item At 75K Miles?
Old Jan 25, 2013 | 10:28 AM
Dust N Bones's Avatar
I had to bring my 5.5 Gen to the local Firestone shop last weekend because I picked up a screw in one of my tires. While it was there they of course gave it a once over to see how much extra money they could get out of me. They told me I should consider replacing the struts because they would be considered a maintenance item at about 75K miles which ironically is almost the exact miles on my car. They admitted that the struts are not leaking and don't show any signs of failing.
I know the struts won't last forever but the stock suspension still seems to ride like it did when new. Unless they start leaking or show other signs of extreme wear when should I consider replacing the struts?
Old Jan 25, 2013 | 10:45 AM
NmexMAX's Avatar
dot dot dot ...
If it aint broke, don't fix it.
I'm assuming your car is all stock, suspension wise?
BUT, these cars are 10+ years old (last manufacture known date of 2/03 for 03's), so keep it on your radar.
djfrestyl might be a better guy to ask. He has an entire thread on suspension a few down from this one.
Old Jan 25, 2013 | 10:48 AM
Catch22's Avatar
If the ride is still good - i would not replace your struts. I replaced mine at 120K - and to be honest the ride didn't change at all. I was hoping that the new struts would solve a clunking in the rear end issue. Now I have new struts all around and the Clunk still exists....if they aren't leaking and the ride is still good - don't replace them
Old Jan 25, 2013 | 12:53 PM
Yes the car is all stock. That is kind of what I figured and I definitely knew better than to take their word for it but it did get me thinking if there is recommended time when they should be replaced.
Old Jan 25, 2013 | 01:36 PM
TallTom's Avatar
You're fine running the stock setup. I replaced mine around 100k and they still weren't leaking. I replaced them and installed H&R springs at the same time.
Old Jan 25, 2013 | 02:06 PM
DennisMik's Avatar
75K is maybe a little early to change shocks unless the roads you drive on are what is called "washboard" meaning they are slightly hilly. But by 100K, they do need to be replaced. They may not be leaking but the o-rings inside are wearing out.
Old Jan 25, 2013 | 02:48 PM
RA030726's Avatar
I'm nutty for Nissans
IMO mileage is irrelevant. Just check for leaks.
Old Jan 25, 2013 | 07:01 PM
I know that they'll need to be changed eventually but 75K almost seemed a bit too soon to me if they aren't leaking. I'll probably start thinking about having them replaced around 100K miles.
Old Jan 25, 2013 | 07:19 PM
MichIndOh's Avatar
I am an engineer for a company that makes shocks/struts and if they aren't leaking and you don't experience excessive bouncing when going over bumps (your car should go up and down once and stop) then they're fine. I had 285K on my last car with original shocks/struts (struts are on the front and shocks on the rear). They weren't as stiff as they were new, but they still performed just fine and never leaked.
We recommend replacing them every 50K miles, but thats usually only needed if you use them heavily (if you live in Michigan, I'm talking about you!). There aren't o-rings in shocks, but lip seals that the rod goes in and out of (that's what usually leaks) and on the piston inside the shock. If they don't leak, what usually wears out is the metal discs that control the fluid flow and do the damping. If the suspension starts to feel soft, or the car dips or dives more than normal under breaking or acceleration, then they need replaced. Hope this helps!
Old Jan 26, 2013 | 08:45 AM
fat_kid's Avatar
Do the bounce test and you can find out if they are worn out or not.
Old Jul 26, 2022 | 11:16 AM
mahanddeem's Avatar
I guess OP (and I'm in the same boat) is asking: do you really need to change the spark plugs regardless of anything?
I for example have 104k miles, engine idles and works flawless, and get 24 to 25 mpg (manually calculated, I log every fill up with mileage. Dash shows 25.8mpg). Still I need to change them (now)?
Old Jul 26, 2022 | 07:37 PM
TallTom's Avatar
Personally, if the car is running great, I would wait and see if any repairs are needed between now and 125k. I would then combine the spark plug replacement along with the other repair.
Unless you are handy with some tools and just want to do it in an afternoon in your driveway. The hardest part are the bolts to remove the upper intake manifold.
Old Jul 26, 2022 | 07:49 PM
mahanddeem's Avatar
Thanks for the reply.
Although my bad I don't know why I posted my question here. I confused it with another thread where OP asked should spark plugs be replaced at 100k miles.
Anyway good to know thanks again
rLx77
Mar 15, 2005 04:42 PM
kmanCA
Jun 1, 2004 08:17 PM
fflan513
Mar 1, 2003 10:22 PM
Parsec
21
Sep 12, 2002 10:51 AM
lduthler
May 25, 2002 09:07 AM
