Info on brake kit
Info on brake kit
OK I'm thinking of picking this up but I noticed something odd. In the specs area look ay the rear bolt measurement says 4.25..... looking for opinions here..... has any one tried these or does any one have other recommendation for a brake kit.... these go for $228 and shipped they are $249. Id like to stay under $300 of possible. Over already ordered new calipers and brackets for the rears as well.
http://www.rockauto.com/catalog/moreinfo.php?pk=3793554&cc=1431961
The rears are not going to fit on the Maxima. The bolt circle is 4.5 inches on both the front and rear. The hub hole diameter is bigger than the Maxima needs, so that's not a problem.
Is this kit supposed to be for a Maxima? If it is, I would call them and get that double checked, because what is stated is incorrect for a Maxima.
I just ordered rear calipers and brackets for my car. Would the 6th bbk still work with those?????
..Edit
I did some reading and now know the bbk kit would be for the front. Im kinda interested in doing this now. I just need to find out what years exactly fit my 02. And is there a special option on the 6th Gen for the "bbk" is are the oem brakes referred to ad that because the ate bigger than the 5.5 Gen?
Dennis yes the kit is for maxima and i35. I wasn't aware of the hub size issue too... I guess I'm going to have to give power stop a call for the real specs.
..Edit
t6378tp
Sep 29, 2018 04:27 PM
