Any suggestions on what to replace for a clutch pedal groan
Old Feb 4, 2013 | 08:47 PM
ajahearn's Avatar
Clutch pedal has been making a groaning/spring compression noise for the last 5-10k. It is clearly around the clutch pedal as the noise can be heard with the car off. I tried lubricating the assist spring with both grease and WD40 but no luck. Should I just replace the whole assembly or does someone have a specific suggestion? Thanks.
Old Aug 27, 2013 | 09:44 AM
FMSCMaX's Avatar
Did you ever figure this out? Mine started doing the same thing yesterday.
Old Aug 27, 2013 | 10:44 AM
DennisMik's Avatar
There are several parts of the clutch pedal assembly that Nissan recommends you lubricate on a regular basis. See page CL-5, parts 4, 14, 15, 18 and 19.
http://boredmder.com/FSMs/Nissan/Maxima/2003/CL.pdf
Old Aug 27, 2013 | 05:55 PM
mrjones's Avatar
spray it with some lithium grease. Mine did the same thing, immediate fix.
Old Aug 28, 2013 | 05:46 AM
TriniSpeC's Avatar
Slave cylinder is likely on its way out or the plunger for the clutch under the dash. Any clutch engagement issues?
Old Aug 28, 2013 | 02:19 PM
FMSCMaX's Avatar
Lubricated all the contact points yesterday and the noise immediately went away. Thought it might come back this morning due to cooler temps but so far it is all quiet.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
maxima-junky
Aug 13, 2015 09:59 AM
ef9
Aug 13, 2015 01:19 AM
