Quick Charcoal Canister Vent Valve Q
Old Feb 5, 2013 | 03:34 PM
Will's Avatar
Hi gents, if I were to fit a good charcoal canister vent valve from a 5th gen (2000-2001) into a 5.5gen (2002-2003, 3.5L drivetrain), will it be compatible and turn off the Service Engine Soon light, or do they have to be the exact matches by VIN number?
The only difference in part#s in the Nissan catalogue is the second set of numbers, 14935-5M00B for the 5.5gen and 14935-54U0D for the 2000-2001 models.
Anyone ever experimented and can report, or know?
Thank you!
Old Feb 5, 2013 | 04:30 PM
joeltender's Avatar
I guess your a victim of Ontario's new e-test rip off?
what codes were you getting?
Old Feb 5, 2013 | 07:44 PM
knight_yyz's Avatar
Toolie
the canisters are the same Will. There is probably a different number for something that is silly but different between models. My canister is a 5th gen had it for about 4 years now.
Old Feb 9, 2013 | 03:33 AM
StevieB's Avatar
Hi Will,
I'm guessing you did some research and may have already seen this, but just in case, have a look at
http://forums.maxima.org/5th-generat...02-maxima.html since it has some useful info, especially post #14.
Old Feb 9, 2013 | 06:01 AM
Will's Avatar
Thanks very much StevieB and my Ontarian chums. Yes, I did see that thread. Interesting on the applying 12V bit.
Old Feb 13, 2013 | 06:26 AM
jesseroscoe's Avatar
Had the same problem on my 2003 last year. Tried the 12V method and saw no valve movement. Ended up replacing just the valve. The funny thing is, I already knew from reading the forums that some ppl recommended cutting the valve off the canister so as not to risk cracking the canister itself. So I started there, cut the valve away with a dremel, only to find that the remaining studs turned freely after all. Perhaps it was the dremel vibration that helped. So I was able to put the new valve on without needing JB Weld and codes haven't been back.
Old Feb 13, 2013 | 12:50 PM
knight_yyz's Avatar
Toolie
I add air tool oil to the valve before the 12 v test.
Miket2006
Mar 1, 2021 03:55 AM
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
