parking
Old Jan 11, 2002 | 02:07 PM
ZIPPIN's Avatar
Mauja He Mauja
parking
How do u guys park your car.
After stopping, do u first put the car in N, pull the emergency brake and release the foot brake pedal. then put it in park?
or do u just put the car in park and let the transmission hold the car???
a guy at AMMOCO transmission told me that , especially if you park on slopes, to use the emergency brake. so that the car is stopped by the emergency brake, not the transmission. he said that leaving the car in P will put stress on the trnamission, especially if the car in parked on a slope
Old Jan 11, 2002 | 02:12 PM
TimW's Avatar
The silent but deadly Moderator
true...
you can wear out the stop/tooth thing that holds the transmission. you dont have to do anything but stop, pull brake, then P. You just want to avoid that jolt of letting off the brake and lurching the car while in P.
Also, its good to startup, hold brake, go to D or R, then take off ebrake. because releasing and binding the transmission anytime is bad. I find it harder not to do when I get back in the car, not turning it off.
Also, if someone bumps your car when parked, your tranny doesnt take all the force. (yeah, it only holds the rear, but at least your car will be harder to bump and move)
Old Jan 11, 2002 | 05:39 PM
ZIPPIN's Avatar
Mauja He Mauja
damnnnn noone else parks their car i guess.
Old Jan 11, 2002 | 05:48 PM
TimW's Avatar
or maybe
everyone just thought the question was answered.
Old Jan 11, 2002 | 09:34 PM
Spudskier's Avatar
Re: or maybe
Well.... I leave it in 2nd, keeping the clutch in, I put on the ebrake, then turn the car off and release the clutch a few seconds afterwards just to make sure the car is actually off. I then check and recheck the ebrake because I'm paranoid I'll leave it in neutral with the ebrake off...
Old Jan 11, 2002 | 09:41 PM
CharlieNewbieMax's Avatar
Re: parking
to park, i go: hold the brake, shift to P, pull hand brake, release brake.
to leave, i go: hold the brake, release hand brake, shift to R or D, release brake.
am i doing good or bad
Old Jan 12, 2002 | 12:19 AM
TimW's Avatar
yeah.. thats right..
you just dont want the weight of the car binding the tranny.
Old Jan 12, 2002 | 07:48 AM
ZIPPIN's Avatar
Mauja He Mauja
Re: yeah.. thats right..
see if this makes sence. for A/T,,i put the car in N,,pull the
e-brake, let go of the brake pedal,,,this way, not only is the car in neutral,,but has no weight on the tranny what so ever. so after the car sits with the e-brake on, i push in the foot brake and put it in P. i just notices that if i just pulled the e-brake and put the car in N, it still had some weight on the tranny,,,but if i put it in N and pulled the e-brake,,,the weight was on the e-brake...
i am not making any sence anymore that 1800 tequila, i drank last night, is still in my stomach
Old Jan 12, 2002 | 11:41 AM
TimW's Avatar
if....
if you have trouble or any resistance getting out of P, then you are doing it wrong.. that simple.
Old Jan 12, 2002 | 01:31 PM
ZIPPIN's Avatar
Mauja He Mauja
Re: if....
exactly what i wanted to say,,,,thanks
Old Jan 12, 2002 | 03:16 PM
DOHC 30 V6
Getting out of park....??
Im not sure hwy, but sometimes when im on an incline, even a slight one, its physically hard to get the shifter out of the Park mode. Is there a reason for this?? it goes eventually, but its just a pain in the *** at first.
Old Jan 12, 2002 | 03:29 PM
Newman's Avatar
Re: Getting out of park....??
are you not using the e-brake? if you arent then that is why.
Old Jan 12, 2002 | 03:49 PM
DOHC 30 V6
Re: Re: Getting out of park....??
Nope, never have, tonight i will give this a try. Thanks for the help
Old Jan 12, 2002 | 08:05 PM
punkdork's Avatar
Re: Re: Re: Getting out of park....??
Be sure to set the ebrake BEFORE letting of the brake. Otherwise the load of the car is on the tranny and that is why it's hard to get it out of park.
Old Jan 13, 2002 | 05:25 PM
Newman's Avatar
Re: Re: Re: Re: Getting out of park....??
right. do the process CharlieNewbieMax said earlier. thats the exact way i do it.
Originally posted by CharlieNewbieMax
[B]to park, i go: hold the brake, shift to P, pull hand brake, release brake.
to leave, i go: hold the brake, release hand brake, shift to R or D, release brake.B]
Old Jan 13, 2002 | 05:32 PM
costcowholesale's Avatar
thats how I do it to park:
brake & put it in N until stopped let brakes go, E-brake up, then to P.
to go I press teh brake peddal 1/2 way, shift it into R or D depends direction, then ebrake down then go.
Old Jan 13, 2002 | 06:54 PM
2k2kev's Avatar
It's chrome alright...
what about winter?
is that how you do it in the winter, too? Northern Maine gets pretty cold, and wet brakes, applying the e-brake, and letting a car sit for a few hours can sometimes mean the car won't move for a few days.
In the winter, I try not to park on hills and don't use e-brake.
Old Jan 13, 2002 | 07:01 PM
Re: what about winter?
good point, but I never have any problem moving after marked outside for a couple hrs during a snowstorm
Old Jan 13, 2002 | 07:07 PM
2k2kev's Avatar
Re: Re: what about winter?
snowstorm isn't the issue... it's extreme cold. I've seen vodka freeze nearly solid in Feb and that's not supposed to happen (it wasn't in *MY* trunk.. ;-). The problem is driving heats up the brakes, they get wet, car is parked, brakes freeze. I didn't believe it until it happened to me. I take the extra drive around or park farther away so I don't have to park on a hill in winter up there (parents live wayyyyy up, I live in southern NH).
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
05RLS2
Sep 27, 2015 09:24 PM
