What to use to seal this?
Old Feb 14, 2013 | 06:28 PM
Genes1s's Avatar
My 00 maxima se radiator is leaking at the top seam by the inlet hose. What can I use to seal the leak in the mean time till I get my radiator.
Old Feb 14, 2013 | 06:32 PM
rebelhell's Avatar
Not much you can do. Hope you're not driving it like that. Mine blew while driving and sprayed most of my coolant all over the engine compartment. Ended up changing the radiator on the side of the road. What's keeping you from getting a new one right now?
Old Feb 14, 2013 | 06:47 PM
Tommy Boy's Avatar
I'm not a big fan of the "stop leak" additives. They can cause more problems than they are worth! If you do use any of those stop leak quick fixes make sure to flush your coolant system completely BEFORE you install your new radiator.
I would simply wait until the car is cold, turn the radiator cap until the pressure lock is off but the cap is still retained and drive it that way until you get the new radiator. Being that it's winter in our hemisphere and not summer, you probably won't have any overheating issues.
Old Feb 14, 2013 | 06:48 PM
Genes1s's Avatar
It's no the way here, probably next Monday. This is my Daily driver. I've never had over heating issue but I started to smell coolant sitting in the traffic and mine also sprayed all over. Car's been sitting for few days now. Judging from the label,the radiator is still original made by Calsonic Japan. What I don't understand is that support piece s made out of plastic.
Chris Gregg's Avatar
Get Off My Lawn
I tried to fix mine until my new radiator arrived. Used JB Weld, twice. No luck. When these tanks crack, that's pretty much it. DO NOT try to use anything that gets added to your coolant either. They don't work well (at best), especially not going to help on a plastic tank, and at worst they will cause problems elsewhere.
Get the koyo and avoid driving the car.
Old Feb 14, 2013 | 07:13 PM
Genes1s's Avatar
I was going to get koyo brand but couldn't wait till next week, I bought the one from Autozone today with lifetime warranty and they should be here this weekend for Monday install. I also get the thermostat also. I was glad it was the radioator not the water pump
Old Feb 14, 2013 | 07:28 PM
Nelsito65's Avatar
I'm surprised Autozone didn't have it in stock; should've gotten it on the spot and take advantage of the weekend for the installation (unless someone else is doing it for you). In any case, you're way much better taking care of that problem now before it becomes something much worse.
Old Feb 14, 2013 | 07:59 PM
cabernet's Avatar
Don't waste your time. It's done for. Buy a new radiator. Common Max radiator failure.
Old Feb 14, 2013 | 08:11 PM
Genes1s's Avatar
Yeah, they have to get it from Seattle. I will do the R&R just didn't,t have time this weekend....busy retrofitting....
Old Feb 16, 2013 | 08:41 AM
Genes1s's Avatar
Got the Radiator last night and installed it. Took 2 hours,majority of the time was dealing with plastic clips,drain time, and clean up. Let the engine running till the fan came n with no cap to make sure no air was trapped. The only thing that I was concern was that the shroud fan mounting had to be self tapped with the original screw since it didn't have thread for the 6mm bolt, but it looked OK after install and no hair line damage
Old Feb 16, 2013 | 09:15 AM
Child_uv_KoRn's Avatar
Bad *** Newb
You will need to drive it around and bleed the air out (after it cools down a bit) to make sure.
Old Feb 16, 2013 | 09:40 AM
Genes1s's Avatar
Bleed the air out by taking the radiator cap off when cools down?. or is there any bleeder valve somewhere.
I took the radiator cap off and run it for 15 minutes idle/engine fan turned on.
Old Feb 17, 2013 | 09:36 AM
user name001's Avatar
a good thing to do, is crack your C.T.S (coolant temp sensor) loose or remove it completely when filling. being one of the higher points, it will allow most of the air to escape. once you see it drizzling out tighten and top off.
Old Feb 17, 2013 | 01:01 PM
luvlexus101's Avatar
2 hours to change it seems a bit much. But yea I run it with the cap off until no more bubbles appear.
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
mpbclutch33
Dec 26, 2015 11:11 AM
The Wizard
24
Oct 1, 2015 08:47 PM
Gingerheadman
Oct 1, 2015 05:11 PM
