no air no a/c no heat doesn't blow air
so after i fixed the misfire issue im heading to my next problem issue.. no heat/no air condition. i did search for no air no heat but only thing i've found was heat coming out cold.. mine doesn't blow any air at all. can anybody head me to some right direction what the problem is?
I've repaired the fan control module in my 03 with automatic climate control. The component inside the module that failed was a "thermal cutoff/cutout". Following something I found on the web a couple years ago, I was able to solder a bypass wire in place long enough to test and verify the module as the problem. Ordered a new thermal cutoff from digikey and replaced it, whole thing cost me $4.50. Not sure if that procedure is on this site, but you can probably search it or google it.
pears
09-18-2015 05:25 AM
DayHeyZeus
09-11-2015 03:17 PM
