Exedy Stage 1 + Fidanza flywheel + STS
Old Mar 4, 2013 | 11:31 AM
Berserk247's Avatar
Ok guys, so I've heard mixed things about this setup. Do any of you know if there will be "chatter" with this combination at all? Also if any of you are in San Diego, do you know of a place where I can get this stuff installed? (reputable/knowledgeable place preferred of course) called this place today and they guy was telling me not to go with a "stage anything" because it will wear down the flywheel faster than an OEM clutch, even though I told him I was upgrading the OEM flywheel with the Fidanza. I'm assuming there is SOME truth to this, but not as bad as he was trying to make it out to be. Thank you
Old Mar 4, 2013 | 01:16 PM
MrEous's Avatar
^ Jeff™
Exedy stage 1 is OEM setup from what I have read here...or at least Nissan uses Exedy to make OEM clutch disks.
I don't have information on the setup other than a 4th gen friend that had an issue with the Exedy+Fidanza setup...he did have chatter. But that should go without saying I doubt he broke it in correctly.
Myself, I went with a Bahnhof clutch and Fidanza setup. Installed 2 wks ago and 1/4m tracked it yesterday with -0- slippage and -0- chatter, I'm a very happy camper.
Check your local forums (at the bottom of the forum listings) for your area. There might be some Maxima owners that can help.
Old Mar 4, 2013 | 01:42 PM
digitalbow's Avatar
Hi,
Have you searched the forum? Your tolerance for "chatter" boils down to personal preference. The feel from the Exedy stage 1 is a little more harsh than their OE replacement (to caveat what the post above me states, they are in fact different), but carries a rating of over 300lb·ft wheel for their VQ30 application. Some find that it is too much feel for encountering daily stop-and-go traffic, so unless you need that kind of torque capacity, their OE-type may suit better.
The Fidanza flywheel is a single-mass unit, just like the OE VQ30 flywheel, so there should be no issues there. Complaints about NVH with lightweight flywheels are usually when people go from a dual-mass to a single mass and are not yet adjusted to more foot precision from a stop.
Old Mar 4, 2013 | 02:14 PM
MrEous's Avatar
^ Jeff™
^^ Thanks, I knew I stood to be corrected on the Exedy stage 1 info...
Old Mar 4, 2013 | 07:16 PM
NismoAce's Avatar
Fidanza and exedy stage 1 was the setup I went with and I dont regret it. I have 0 chatter. The fidanza is solid mass but the exedy stage 1 is spring loaded = ideal. This makes it like most setups and the only way it should be setup.
a good read
http://forums.maxima.org/5th-generat...-flywheel.html
Old Mar 5, 2013 | 07:28 AM
RobertColianni's Avatar
I have the same setup. The only downfall is that the flywheel ends up being so light that you get a little delay if you don't shift at the perfect time. Once you get used to it and rev higher, you're good. No chatter at all and I haven't gotten a lick of wear.
Old Mar 5, 2013 | 07:54 AM
toby's Avatar
I also have the same setup minus the sts . It did take a little getting used to at first but like robert said u have to a little higher . I have had it for almost 2 years now with no complaints
Old Mar 5, 2013 | 11:46 PM
Berserk247's Avatar
A little delay as far as what? 0.o I've also heard that the gear around the flywheel is prone to coming loose for some odd reason? IE this
Also for those of you with the set up, what kind of improvements should I expect to see? Been pretty excited about the whole thing.
Old Mar 6, 2013 | 08:03 AM
Read this. It's my experience when I switched to an Exedy OE Replacement with Fidanza Aluminum. I later switched to Exedy Stage 2 and basically got the same results.
Old Mar 6, 2013 | 10:42 AM
MrEous's Avatar
^ Jeff™
Originally Posted by Berserk247
A little delay as far as what? 0.o I've also heard that the gear around the flywheel is prone to coming loose for some odd reason? IE this http://www.youtube.com/watch?v=ruKEI20aJjk
Don't know what application that video was for but my fidanza had 9 bolts going around for the gear around the flywheel. Fidanza is also what JWT uses and I trust their knowledge.
Improvements...less stress on engine? There's a good weight difference between stock flywheel and lightweight.
Along with a minor UTEC tune I gained .3 in the 1/4 along with 4mph in trap speed. I have yet to go back to the dyno after only flywheel install but I definitely feel like I've gained tq.
Old Mar 6, 2013 | 10:52 AM
Originally Posted by MrEous
I have yet to go back to the dyno after only flywheel install but I definitely feel like I've gained hp.
You mean torque.
Old Mar 6, 2013 | 11:05 AM
MrEous's Avatar
^ Jeff™
Originally Posted by RobertColianni
You mean torque.
Good catch...correct
Old Mar 7, 2013 | 03:46 PM
95VQ30's Avatar
I had some chatter in my car some months back- it ended up being a bearing in the trans.
litch
123
Jan 4, 2024 07:01 PM
BkGreen97
Apr 2, 2016 05:47 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
sliptap
Sep 30, 2015 05:57 AM
