Weak car start?
Old Mar 7, 2013 | 11:13 AM
asianstyle's Avatar
Weak car start?
its been really cold around here and my car has been acting like the battery is dying. it will start up but very weak sometimes. i had the battery and alternator tested at the auto store and they said they were fine. what is my problem then? today when i got in the car my mileage counter was reset even though i didn't disconnect the battery. anyone know what's going on? please help. thanks
Old Mar 7, 2013 | 11:18 AM
TallTom's Avatar
Clean the ground connections, starting with the one on the battery.
Old Mar 7, 2013 | 11:55 AM
asianstyle's Avatar
They look clean to me but I'll try it anyway. Thanks
Old Mar 7, 2013 | 07:26 PM
DennisMik's Avatar
Your mileage counter (as you call it) being reset is another problem you are having. It should not be reset just because you disconnect the battery.
I have this problem, too and if I ever I figure it out, I'll let you know.
Old Mar 7, 2013 | 07:31 PM
Nopike's Avatar
Could be your starter is going bad. Especially if it's original. My car had weak starts for a couple of months until the starter finally died.
Old Mar 7, 2013 | 08:26 PM
asianstyle's Avatar
Lol. Odometer I meant say. This has only happened to my odometer once so far. Yeah for sure let me know if you find out anything. I will have to check my starter also. Thanks
Old Mar 9, 2013 | 10:02 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Is not ur starter, if the starter is going bad it will make a noise or just die. Check your terminals but if the battery was tested thats not it. Your alternator is going bad. Do this simple test, diconect the positive terminal while the car is on, if the car dies, there is your answer... New alternator.....
Old Mar 9, 2013 | 10:22 AM
jandk's Avatar
Ground wire might be full of dirt..clean it up or add another ground wire.
Old Mar 9, 2013 | 10:30 AM
DennisMik's Avatar
Originally Posted by Lontar1
1 - Is not ur starter, if the starter is going bad it will make a noise or just die.
2 - Your alternator is going bad. Do this simple test, diconect the positive terminal while the car is on, if the car dies, there is your answer... New alternator.....
1 - Not true. If the lubrication in the planetary gearset is drying up, the starter will spin slower, i.e., crank the engine slower, and you might think the battery is not fully charged. Other than sounding slower, the starter sounds normal.
2 - This is not a good thing to do to the Maxima. Without the load created by the battery, the voltage regulator can cause the alternator to go to 18 volts. It is much better to use a voltmeter. Good alternator = about 14 volts, bad alternator = battery voltage.
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Feb 1, 2016 12:45 AM
Stagnet04
Aug 16, 2015 11:15 PM
Trin1j23
Aug 12, 2015 08:31 PM
mrgooch
Aug 9, 2015 11:00 AM
