Fog Lights get brighter with throttle
Old Mar 4, 2013 | 10:45 AM
Prophecy99's Avatar
So the background. I have the foglight re-wire mod and that was the only reason I was able to notice this. I have a grounding kit (discontinued blehmco). I have direct replacement PIAA Xtreme White H3 bulbs no aftermarket HIDs. And I have a new battery as of Dec 2012 (previous battery lasted for 5 years).
So Im sitting in the car with the car running and only the daytime running lights (DRL) and foglights are on, and if I hit the gas I can notice the fog lights become significantly brighter. What gives? Is this normal? It was suggested that might be an alternator on its way out. Just wondering. Please remember its nothing you could notice with the low beam HIDs on because they take up the majority of the lighting.
I also have noticed a few other things since the battery replacement, all interior lights seem to be dimmer at idle (dash, ceiling light) and are effected by throttle also. I never noticed this before on the original battery that came with the car.
It is my thinking that a grounding kit should eliminate these kind of fluctuations in the lights etc. and if IIRC I never had these dimming issues before. Could it be a weaker battery type? or is something else going on like the 10 year old alternator?
Old Mar 4, 2013 | 10:49 AM
Amerikaner83's Avatar
Probably BOTH weaker battery type and old alternator.
Old Mar 4, 2013 | 11:30 AM
DennisMik's Avatar
Get a voltmeter and check the voltage when the car is at idle and when the engine is at 1k rpm and 2k rpm. Let us know.
Old Mar 4, 2013 | 07:18 PM
quick-e's Avatar
Check your belt on the alternator too. It could be slipping or just a bad alternator or your idle could be too low as well.
Old Mar 4, 2013 | 07:20 PM
T_Behr904's Avatar
This
And this
Old Mar 5, 2013 | 07:31 AM
RobertColianni's Avatar
It's your alternator...
Old Mar 9, 2013 | 09:22 AM
Prophecy99's Avatar
w voltmeter in dc volt mode
Car off = 12.9v~13.2v
Car On @ Idle (820 RPM approx)= 14.2v solid
Car on w/ 1k RPM = 14.1v~14.2v
Car on w/ 2k RPM = 14.1v~14.2v
Thanks for the help all.
Old Mar 9, 2013 | 10:41 AM
DennisMik's Avatar
The voltages sound good, but I should have been a little more specific on the voltage testing. Immediately after start-up, the voltage will be at the 14 volt level at all rpms until the battery is re-charged. After that, the alternator voltage will vary a little bit with the engine rpm and the electrical load. At idle the alternator cannot produce its full output, the engine has to be at around 1500 rpm (I think).
Anyways, a little bit of the lights flaring up is normal, but bad connections and a weakening battery can make this worse.
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
JoshG
Sep 5, 2015 10:10 PM
Maxboy23
Sep 4, 2015 06:04 PM
