power steering pump whine?
Old Mar 10, 2013 | 02:15 PM
rblower2012's Avatar
Hey guys. Today as i was driving i randomly started to get or at least it sounds like my power steering pump "whining" with a little bit of a squeal from a pulley/tensioner. so i pulled over and checked the fluid and it was fine and checked if my power steering was working and it was with no abnormal loss of "power" at the steering wheel. The noise is constant and doesnt go away (even after WD40) So is my power steering pump going? Do i need a new pulley? Help me out! Thanks in advance.
Old Mar 10, 2013 | 02:17 PM
And to make this clear, the whine and squeal are two seperate problems. The whine is most likely power steering i just dont have an explination of why its whining. Thanks for any help!
Old Mar 10, 2013 | 06:56 PM
Gizm0's Avatar
Check your high pressure power steering hose for leaks, a common issue on our cars...
Old Mar 10, 2013 | 06:59 PM
My fluid level hasn't been dropping so I don't suspect any leaks but ill check it out
Old Mar 10, 2013 | 07:06 PM
BlackThornDemon's Avatar
You said its constant? If its the power steering pump you should only hear it when you turn the wheel. Its not easy to mistake a psp whine for something else, you know if you've ever heard it before.
Old Mar 10, 2013 | 07:32 PM
I've heard the ps whine plenty of times lol and it has that whine to it. And yes its constant and ive driven about 80 miles in the last two days and the fluid level hasn't dropped... I'm stumped
Old Mar 10, 2013 | 10:38 PM
kbohip's Avatar
Did someone secretly swap your oem high pressure hose with an Edelmann?
Old Mar 11, 2013 | 05:24 AM
Nope still an OEM hose. Ill get my car on a lift today. I don't think its a leaky hose
Old Mar 11, 2013 | 05:03 PM
It was my a/c compressor bearing. Problem solved!
lowpost99
Oct 26, 2025 06:53 PM
RWCreative
Sep 21, 2015 11:01 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
rnb754
Sep 14, 2015 11:39 PM
SusieQQ
Sep 9, 2015 12:14 PM
