Installed a Warpspeed Y-pipe, not impressed with quality
Old Mar 21, 2013 | 10:26 PM
  #41
2kMaxim's Avatar
Not sure it was the PB that made you puke. I noticed last time I had to do a lot of work under my car on jack stands, something about being on your back in a confined space using tools makes you light headed and nauseous. I had to take several breaks for the same reason.....to get air. Might be something to do with blood flow in a confined space?
Old Mar 22, 2013 | 08:02 AM
  #42
DennisMik's Avatar
You have a good point and it might have played a part but that PB Blaster does not agree with me. Last fall I replaced both axles on my other car and I spent a lot of time replacing the axle seals. The left side took me a couple of hours and I didn't have that problem. Some people can't deal with certain things is all I can say.
Old Mar 22, 2013 | 09:22 AM
  #43
FastnFuriousMax's Avatar
i love the smell.
Old Mar 22, 2013 | 09:38 AM
  #44
2kMaxim's Avatar
Me too...thats why i was pondering...haha
Old Mar 23, 2013 | 07:51 AM
  #45
DennisMik's Avatar
Originally Posted by FastnFuriousMax
i love the smell.
of coure you must know that I think you 2 guys are sick
Old Mar 23, 2013 | 11:58 PM
  #46
2kMaxim's Avatar
Bleach. Bleach will make me puke.
Old Mar 24, 2013 | 01:26 AM
  #47
defiance's Avatar
I have had good luck/results with my 4th gen Warpspeed Y pipe,went on like a glove and made alot more power. But now with the stricter emissions of the 2000 Cali Spec I have now I dont know if its worth the headache.
Old Mar 24, 2013 | 10:15 AM
  #48
DennisMik's Avatar
When you put a Y-pipe on, you eliminate the pre-cats. The pre-cats reduce emissions after a cold start for a fairly short amount of time while the main catalytic converter heats up. When the main cat has heated up, the pre-cats don't make any difference.
Since I don't live in Jersey, you will need to find out the exact testing procedure used. If they do a cold start emissions test, you will probably fail without the pre-cats. But if Jersey doesn't do a cold start test, just make sure the engine (and cat) all warmed up.
Old Mar 24, 2013 | 06:29 PM
  #49
defiance's Avatar
Very interesting info Dennis, but would I still delete both precats on this 2000 Cali Spec ?
The exhaust on this car is different from my old 96,with more 02 sensors and if im not mistaken one of the precats have moved to the exhaust manifold while the other is still built on the y pipe.
Old Mar 24, 2013 | 06:59 PM
  #50
DennisMik's Avatar
It sounds like your 96 was a Fed spec car. On Cali cars, the left pre-cat (radiator side) stays on the car. The Y-pipe does not connect to the exhaust manifold on the left side.
Read this thread that is also going on. http://forums.maxima.org/5th-generat...-owners-3.html
For Cali spec cars:
For Fed spec cars:
Old Mar 24, 2013 | 08:50 PM
  #51
2kMaxim's Avatar
It is. Im not a link man yet but someone, I think NMex posted a link on one of my threads that showed the loss of HP from having the bank 2 precat on was only like 1-2 hp vs the fed spec Y pipe.i think it still gained like 10whp....Cali version that is....Thats pretty cheap HP on an NA car. The sound from what I can hear in the videos really makes the maxima sound dangerous..lol. Not to mention no SAFC tune yet......ypipe is worth it still on a 2000 cali spec. Its my next move.
Old Mar 25, 2013 | 05:28 AM
  #52
5aprilc's Avatar
I noticed a considerable difference in power after I installed my Cali Spec Y pipe and catback exhaust. And I still have the stock bank 2 precat. (Not for too much longer)
Old Mar 25, 2013 | 06:58 AM
  #53
carsnwomen91's Avatar
I have the stainless on mine, no issues whatsoever 3 years. Mine was packed in a nice cardboard box with lots of packing peanuts. It did take a while to get (almost a month) but that was only cause i had to wait for their stainless steel supploer to come through
Old Mar 26, 2013 | 08:46 AM
  #54
vq30nismo's Avatar
Mine took about 15 days to get to my door but I know it was going to take some time since it says they were made to order. Luckly I have a 2000 fed spec maxima so both of my precats are removed with the y-pipe.
Old Mar 26, 2013 | 09:15 AM
  #55
5aprilc's Avatar
I must have just been unlucky. Because my Warpspeed pipe took 7-8 weeks to arrive at my house. But that's the only negative thing I can say about Warpspeed, because fitment was perfect, and it sounds amazing, and the power gains were very noticeable.
Old Mar 26, 2013 | 09:46 AM
  #56
2kMaxim's Avatar
Ya'll are making me nervous about ordering one. Lol
I do know that with my test pipe i had to call back a couple times...just to stay in their ear. And it came in two weeks.
Old Apr 20, 2013 | 04:44 AM
  #57
used parts's Avatar
amateur hour
Blaming Warpspeed for this is laughable. If you can't center the y pipe with the cat opening, why should anyone believe that the flanges that mate to the manifolds was off?
The gasket looks a little funny from not being properly positioned the first time. The metal crush ring also shows the mis-positioning. At the 10 o'clock position, it is shiny. At the 4 o'clock position, it is covered with soot from being in the exhaust stream. If you look at the left stud hole, you can see the impression of the oblong flange opening extending onto the metal crush ring, my leak.[/QUOTE]
Old Apr 20, 2013 | 09:00 AM
  #58
Stonelove670's Avatar
Mine fit perfect. Took a while for them to ship tho i had to call them twice also it was wrap in Heffty trash Bag.
Old Apr 20, 2013 | 09:47 AM
  #59
5aprilc's Avatar
See, I wasn't kidding about it being wrapped in a black trash bag. Was the box beat to sh*t too?
Old Apr 20, 2013 | 11:12 AM
  #60
DennisMik's Avatar
I expect that when a company provides a product that is supposed to be an exact fit, there will not be a half inch of play at the connection as there was at the catalytic converter connection.
As for the exhaust manifold connections, to take the position that a product could not possibly be made wrong or be defective is pretty naive.
Old Apr 20, 2013 | 11:36 AM
  #61
5aprilc's Avatar
It sounded like he was questioning your ability to install exhaust parts.
Old Apr 20, 2013 | 08:35 PM
  #62
DennisMik's Avatar
That's the way I read it too.
Old Apr 29, 2013 | 06:52 AM
  #63
a33nismo's Avatar
I was alittle worried reading this thread since i already ordered my warpspeed y pipe last month. But it arrived on Friday so i installed it this weekend and the fitment was perfect no leaks at all at the manifold flanges or the cat.
Now i also ordered a new 2.5" magnaflow catalytic convertor off of the that site also when i ordered the y-pipe so maybe that has something to do with the good fitment to the convertor not sure.
I drove it about 100 miles on Saturday and then put it back on the lift to check for leaks but everything was good to go.
Also this was for a 2000 fed spec maxima.
I didn't think these pipe were hand made but maybe they are and thats whats causing some people to have issues and the rest have perfect fits. Also as for how it was packaged it was in a black plastic bag but it was also wrapped in bubble wrap in the box.
Old Apr 29, 2013 | 08:44 AM
  #64
5 ltr. beater's Avatar
just thought id add to the list of people that have a warpspeed y-pipe (as my only performance mod) and had no problems with it whatsoever.
only problem i had was snapping a rusted bolt on the old y-pipe. other than that, quality was good and definitely beats spending an xtra $200 just to have a "cattman" product.
oh and i just passed smog too without any problems.
Old Apr 29, 2013 | 09:11 AM
  #65
a33nismo's Avatar
Yeah i looked into the Cattman y-pipe last month before i got the warpspeed but when i called the guy at Cattman he said his website isn't updated and he doesn't sell the y-pipe anymore he just makes the full header kit for $800.
So you have the warpspeed y-pipe or the full cattman headers.
Old Apr 29, 2013 | 10:46 AM
  #66
just the warp speed y pipe.
Old Jun 22, 2015 | 01:06 PM
  #67
Prophecy99's Avatar
does anyone have any expereince with the WS Y-pipe not fitting with a LTB Stage II
i can't believe i have a shop telling me they cannot get my LTB back on after they installed the y-pipe..............
i am at loss of words.
should i let go of the LTB untill i waste more time on trying a different shop to re-isntall the new y-pipe to work with the LTB?, or find a junk yard y-pipe (oem), and get them to put that on to get my LTB on?
the end goal is to have my LTB.
and mind you these two things shouldn't have an issue fitting according to the LTB website!
Old Jun 22, 2015 | 02:19 PM
  #68
Kevin Trout's Avatar
I have a used Cattman y pipe I can sell you. I also have a ltb2 and can guarantee that they fit together.
Old Jun 23, 2015 | 04:23 AM
  #69
Prophecy99's Avatar
Sounds like an option, pm you about that.
Why doesnt WS-ypipe fit! i think its the shop or my unique car/situation.
They really should fit.
Old Jul 13, 2015 | 12:42 AM
  #70
soloist3's Avatar
I am looking for a Y-pipe for my fed-spec 1996 Maxima, is the cattman still available? Otherwise, anyone selling any compatible y-pipe around here? My flex section is leaking and I would rather do the mod than take it to a muffler shop to have a 20 year old pipe rewelded for 60-80 bucks.
Old Jul 13, 2015 | 02:04 AM
  #71
Cattman is long gone.
Violator
Sep 9, 2015 10:14 AM
jfl330
Sep 4, 2015 01:44 PM
Samedi
Sep 3, 2015 01:07 PM
