2000 maxima transmission drain plug
Old Mar 16, 2013 | 07:22 AM
grip1968's Avatar
were is the drain plug on the transmission, I trying to change my transmission fluid.
Old Mar 16, 2013 | 07:36 AM
mrjasonlyrics's Avatar
I don't want to laugh but I can't help myself... If it's an A/T it will be on the left side of the car, the same side of the transmission. If it's a manual I wouldn't suggest you change it yourself. The car needs to be on a hoist so that you can unscrew the M/T drain plug because there's no other way to add oil if your measurements are wrong.
Old Mar 16, 2013 | 08:44 AM
Pilm's Avatar
The pan is next to the front driver side tire, look for a 19mm bolt toward the back of the pan. I just did mine last week, didn't even need to jack the car to get access to it. I also drained the torque converter using the return line from the radiator, but if you want to keep it simple, just remove the drain bolt and refill same amount.
Old Mar 16, 2013 | 09:07 AM
grip1968's Avatar
sorry it an automatic, so the plu is on the back of the pan????
Old Mar 16, 2013 | 03:31 PM
Pilm's Avatar
On the bottom toward the back (firewall) side of the pan, but it's recessed a little bit, but easy to see once you're on the ground.
Old Mar 16, 2013 | 03:34 PM
grip1968's Avatar
I changed my transmission fluid, I think I put too much in it, cause it shifting funny now. can this be cause of too much fluid in there. do I need to drain some of it out.
Old Mar 17, 2013 | 09:33 AM
Pilm's Avatar
Yes and yes.
Was color of drained fluid ok? Did you use Matic-D for refill?
Old Mar 17, 2013 | 10:15 AM
grip1968's Avatar
the fluid was cherry looking, and I use castrol import tranny fluid for nissan, I check the level before changing it, it was below the hot level, so I drain it. I say about a quart came out, so I put like 4 quarts in there I check the level and it is way above the hot level. so now is when I drive like over and half an hour the rpms jump up to 4 and im only doing like 40
mph. do I need to drain it to get to the hot level, so it can shift right?????
Old Mar 17, 2013 | 11:10 AM
Nelsito65's Avatar
Apparently all you had to do was refill to the proper level.
Assuming you correctly checked the level the first time around and a quart was ALL it came out when you drained it, I'd drain at least a quart or two, then check the level as stated in the manual. At that point, if needed, add a little at a time, re-checking the dipstick until you get the right level.
Old Mar 17, 2013 | 12:35 PM
grip1968's Avatar
so all I have to drain and check the level and that will stop the rpm jumping up when im driving, my transmission never done this until yesterday when I drain & fill it up....
Old Mar 17, 2013 | 02:19 PM
2damax's Avatar
How many miles on car and when was last drain and fill on tranny?
Old Mar 17, 2013 | 02:53 PM
grip1968's Avatar
it have 174000, had a drain and fill like 2
yrs ago
Old Mar 17, 2013 | 02:56 PM
2damax's Avatar
O I was gunna say you did a fill to late in mileage but not if u just did it two years ago
Old Mar 17, 2013 | 03:05 PM
Pilm's Avatar
WTF?? Only a QUART came out on a drain?? You should get ~4 quarts, so either you were 3 quarts low before you started or you meant to say a gallon came out. Something sounds very wrong about this. Actually, I doubt the system could even hold 3 extra quarts, the stuff wouldn't even have poured into the fill tube.
Old Mar 17, 2013 | 03:16 PM
grip1968's Avatar
it took all 4 quarts, but now its rpms is revs high when im driving so I have to drain some of it out, cause the level is way over the hot and cold mark. again if I drain will it stop the rpms jumping up..
Old Mar 17, 2013 | 03:26 PM
Nelsito65's Avatar
If the level is way over the full mark, You need to bring that fluid to the proper level ASAP.
Old Mar 17, 2013 | 04:22 PM
grip1968's Avatar
I will drain it tonite, will that fix the rpms jumping up...
Old Mar 17, 2013 | 04:28 PM
Nelsito65's Avatar
There's no way to find out for sure until you do it.
Old Mar 17, 2013 | 04:41 PM
grip1968's Avatar
cause my transmission didnt start doing this unti I drain and fill it yesterday...
Old Mar 17, 2013 | 04:54 PM
Pilm's Avatar
But why would you put 4 quarts in if you only got 1 quart out, that makes no sense? The problem with overfilling, especially overfilling by a lot, is the system pressure will be very high, and that could cause the problems you see, or maybe you'll blow a gasket if you keep driving it.
Old Mar 17, 2013 | 05:32 PM
grip1968's Avatar
ok I will drain it soon as I get home, will a blown gasket cause the rpm jumping. other then that is shifts fine....
Old Mar 17, 2013 | 06:10 PM
Pilm's Avatar
I'm thinking high pressure could breach an old ATF pan gasket, but if that happened you'd see a leak on the ground.
Old Mar 17, 2013 | 06:37 PM
kc10fish's Avatar
Serious?
Old Mar 17, 2013 | 06:50 PM
grip1968's Avatar
I haven't seen no leaks, at all so I will drain it until it get to the hot mark...
Old Mar 18, 2013 | 07:08 AM
grip1968's Avatar
ok I just drain the about 3 1/2 quarts out if the transmission, its shifting much better. next time I will do I fill only...
Old Mar 18, 2013 | 07:10 AM
NmexMAX's Avatar
dot dot dot ...
http://www.cardomain.com/ride/335521...maxima/page-3/
Old Mar 18, 2013 | 04:09 PM
Pilm's Avatar
Originally Posted by kc10fish
Serious?
A big overfill could also cause fluid to come back up and spill out the fill tube, and if it falls on to something hot like a heat shield, then you'll get smoke, maybe even a nice little fire.
jholley
Aug 11, 2015 09:38 AM
erniel
Aug 8, 2015 09:32 AM
niZ
Aug 7, 2015 10:18 PM
rhonster
Aug 6, 2015 05:46 PM
