O2 sensor
Old Mar 18, 2013 | 10:33 AM
cjandura's Avatar
O2 sensor
Ok how long does it take for the bank 1 sensor 2 code take to go away after a sensor change i did 50 miles so far and it didnt go away and it took 138 miles to get it to turn on after a cel reset for egr.do i have to clear the codes manualy?which i dont want to do because i need to get the emissions test done and the monitors take forever to set the way i drive.
Old Mar 18, 2013 | 11:25 AM
DennisMik's Avatar
It is a complex answer. Nissan uses the term "driving cycles". A driving cycle is starting the car, driving it some number of miles and shutting it off. Nissan says this might amount to 80 miles total, but the miles involved for a city driving cycle are different than a highway driving cycle. Nissan says that some CELs need more cycles than other CELs, but don't say which is which.
Hopefully you have to the end of the month, you just need patience.
Old Mar 18, 2013 | 12:11 PM
cjandura's Avatar
Expired 5/12 lmfao
Old Mar 18, 2013 | 12:35 PM
digitalbow's Avatar
There's no need to double-post/spam the same question in the multiple sub-forums.
http://forums.maxima.org/4th-generat...o2-sensor.html
You might be able to pull it out of the Engine Control System module of the FSM or locate a TSB somewhere. Each system has a different readiness flow. It should contain things like; operate at a certain speed under a certain power load for a specified amount of time, start under certain temperature conditions, accelerate at a certain throttle position, and a few other things - some of which have to be completed in two consecutive cycles. It can take a while to meet all the test conditions, as DennisMik said.
Old Mar 18, 2013 | 01:26 PM
cjandura's Avatar
I will post how i want and where i want Remember that!
Old Mar 18, 2013 | 01:37 PM
Fakie J Farkerton's Avatar
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
