why such bad mpg???
Old Mar 20, 2013 | 02:32 PM
dakota510's Avatar
why such bad mpg???
i replaced my plugs not to long ago and it helped my mpg out but its still super thirsty. i know i have a supercharged car, but if i baby it i should get decent mpg right??? i have an o2 sensor code so if i fix the sensors will that make my mpg better?? fuel filter? mileage is horrible as is.
Old Mar 20, 2013 | 02:37 PM
ateick's Avatar
What kind of supercharger are you runnin?
Old Mar 20, 2013 | 02:43 PM
dakota510's Avatar
vortech v2
Old Mar 20, 2013 | 02:51 PM
5aprilc's Avatar
Well what are you getting for mileage right now?
Old Mar 20, 2013 | 02:53 PM
dakota510's Avatar
havnt calculated it but you can almost watch the needle going down lol
Old Mar 20, 2013 | 02:57 PM
5aprilc's Avatar
That's bad, lol... It could be that o2 sensor that you said you were throwing codes for. I noticed significant gas mileage gains once I replaced two of my sensors.
Old Mar 20, 2013 | 03:03 PM
NmexMAX's Avatar
dot dot dot ...
So, until you post actual numbers, I might be forced to close this thread.
It can't be nearly as bad as my Pathfinder, and that needle doesn't move even when I nail it.
dakota510's Avatar
yeah the reader said 1 upstream and 1 downstream. how hard are they to replace and how do i know which 2 are bad. i know our cars have 4
Old Mar 20, 2013 | 03:10 PM
5aprilc's Avatar
Any idea which banks?
Old Mar 20, 2013 | 03:26 PM
dakota510's Avatar
i think it was bank 1
Old Mar 20, 2013 | 03:54 PM
NmexMAX's Avatar
dot dot dot ...
What injectors do you have and what's your AFR look like?
I don't even have my primaries connected and I get about 22-24, 28 on the highway.
What was the actual measured MPG again?
Old Mar 20, 2013 | 04:25 PM
dakota510's Avatar
Ill get an accurate mpg reading and let yall know
Old Mar 20, 2013 | 05:03 PM
Amerikaner83's Avatar
So in other words, you THINK you've got poor mileage but not even one set of mpg numbers to base your "thoughts" on?
Old Mar 20, 2013 | 07:26 PM
foodmanry's Avatar
Da Roller Coaster!
Make sure you get us actual numbers and not "300 miles to a tank." This is especially critical since you have no real baseline to compare against.
Old Mar 21, 2013 | 09:33 AM
Prophecy99's Avatar
besides all that, fuel filter replacement is definitely recommended you could see 1-3 MPG improvements if original filter is in there.
Old Mar 21, 2013 | 09:35 AM
Not with the 5th gen. 5th gen fuel filter is a "lifetime" filter, located in or near gas tank, not in engine bay.
Old Mar 21, 2013 | 09:40 AM
dakota510's Avatar
i was just about to change the filter under the rear seat? good idea?? its only about 22 bucks
Old Mar 21, 2013 | 09:58 AM
foodmanry's Avatar
Da Roller Coaster!
Meh...it may, it may not impact your mileage.
I would recommend you start calculating your MPG first and getting some baseline numbers before you do any type of work or parts changing.
Old Mar 21, 2013 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
The PROPER way to calculate MPG is:
1. Fill tank completely
2. Reset speedo
3. Drive as far as you feel like, doesn't matter much
4. Re-fill your tank completely
5. Record miles driven between #2 and #4
6. Record Gallons you put in tank at #4
7. Divide Mile reading you got at #5 by Gallon reading you got at #6
EXAMPLE:
1. Fill tank completely done
2. Reset trip odo 0 miles
3. Drive as far as you feel like, doesn't matter much 200 miles
4. Re-fill your tank completely done
5. Record miles driven between #2 and #4 200 miles
6. Record Gallons you put in tank at #4 8 Gallons
7. Divide Mile reading you got at #5 by Gallon reading you got at #6 200 Miles / 8 Gallons = 25 MPG
This is why these threads fail, no one has a bloody clue how to calculate their mileage, and everyone throws out numbers.
Old Mar 22, 2013 | 07:20 PM
Maxx6spd's Avatar
Winter mix gas lowers mpg too
Old Mar 25, 2013 | 09:36 AM
Prophecy99's Avatar
and you are totally correct with it technically being lifetime and with its location, but it is proven to help mileage replacing the lifetime filter, please search there's plenty of info on both 5th and 5.5 gen fuel filter replacements.
OP well worth it on a higher mileage car
chisam14
Nov 6, 2018 08:56 PM
HOKUSMAX
Nov 13, 2017 04:34 AM
ef9
Oct 4, 2015 08:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
Andy29
Sep 29, 2015 05:32 AM
