Window tilts forward in down position
Old Mar 22, 2013 | 05:44 PM
DjHackStyle's Avatar
I just swapped the passenger door in my maxima and i installed my window into it and used the motor and reguator it came with and everything works fine but when window is rolled down almost all the way it dips forward and the back of the glass is pointing up. It feels like the bolts holding the window are loose but i remember tightening them is there other bolts that could be loose on the regulator? What should i look for? I just put this door on i would hate to tear it down again
p.s. On my original damaged door my window worked perfect
Old Mar 22, 2013 | 07:18 PM
rebelhell's Avatar
My first step would be to pull the door panel off and operate it while watching the window as it lowers into the door. Should give you a much better idea of what's going on.
Old Mar 22, 2013 | 08:05 PM
Chris Gregg's Avatar
Get Off My Lawn
These regulators use crappy plastic guides to hold the glass level as it travels. There are also felt lined tracks at the front and rear of the glass to help support and keep the glass stabilizes as it moves. However, if one of those stupid plastic guides breaks, you're done.....and that's exactly what's happened here. You're going to have to replace that regulator assembly. If yours worked, just swap it in.
Only when you do, make sure the glass is out or you risk scratching it. Ask me how I know!
Old Mar 22, 2013 | 08:11 PM
I bought this door and i had to swap the door then i had to swap the wiring and the mirror and the speaker cause i have the bose system and heated mirrors then i swaped the window cause mines were tinted and i swaped the panels cause mines were leather and now ur telling me i have the swap the regulator assembly...... im gonna kill somebody
Old Mar 22, 2013 | 08:19 PM
Get Off My Lawn
Don't shoot the messenger!!
Old Mar 22, 2013 | 08:56 PM
I looked all over and can't find a how to on replacing the Window regulator on the 5th gen anybody got a link or can offer some knowledge.
I'll do it either way but it's nice to have a step by step
Old Mar 23, 2013 | 11:19 AM
I removed the regulator from my damaged door, took me a few minutes 2 gold bolts on top 2 gold bolts on bottom and 3 bolts for the Window motor and it comes out of the lower bigger opening. Surprisingly easy ill install this regulator onto the door currently in my car and ill let you guys know if it solved the dipping Window problem
Old Mar 23, 2013 | 05:22 PM
Get Off My Lawn
You should be able to see the broken plastic clip/guide. Absolutely, let us know.
Old Mar 24, 2013 | 11:34 AM
case closed - worn out regulator
ok i swapped out the regulator, i am now satisfied. the regulator was the cause of the window dipping forward. the guide that slides up and down this rail was not broken however you can definitely see it was worn out and it caused a loose side to side movement. i used my old motor and regulator and its back to where it was but my old regulator also had some play but it was very minimal compared to the problem regulator. is there anyway to replace these plastic guides? just asking for future reference. would seem like a waste of money to replace this whole assembly just for the worn out plastic guide.
Old Mar 24, 2013 | 01:50 PM
Get Off My Lawn
Not replaceable. Although, I highly encourage you to get creative and find a way to make them replaceable. They would sell!!
Fbana41
Aug 29, 2016 12:18 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
