Is it wheel bearing going bad?
Old Mar 28, 2013 | 08:31 AM
admkl13's Avatar
I have a 03 maxima and at speeds exceeding 50 mph, i get a vibration noise from the left side feeling like there is a hump on the tire but the tire looks good. Is it a wheel bearing or the tire just needs balancing?
I should add that I just did allignment a few days ago thinking that was the problem.
Old Mar 28, 2013 | 08:42 AM
DennisMik's Avatar
Swap the front and rear tires to make sure that it is not a tire giving you the vibration.
Old Mar 28, 2013 | 08:46 AM
gatsugansu's Avatar
If it's bad wheel bearing, it should be most noticeable at sharp turns. You could just lift your car and try to shake/move the wheel holding at 9 and 3 o'clock.
Old Mar 28, 2013 | 04:07 PM
Nelsito65's Avatar
Another way to "test" bad wheel bearing is raising the tire, grabbing the spring with your bare hands, and giving the tire a hard spin; if you feel a grinding or rough sensation at the spring, you have a bad bearing.
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
maximusrising
Sep 2, 2015 09:55 AM
