car stalling?
Old Apr 3, 2013 | 04:57 PM
gotendbz1's Avatar
car stalling?
last 2 days when stop at light car has stalled. recently changed my tie rod(outer) and new tires and alignment. No codes, any idea at the cause. Starts back up fine and drives normal.
Old Apr 3, 2013 | 05:02 PM
rebelhell's Avatar
Did you get nice tires or the cheap ones? She might just be upset with you.
Old Apr 3, 2013 | 06:07 PM
Aviation005's Avatar
if your car has an idle air controller valve, check it
if not, it could be fuel pump and i have read a coolant temp sensor can cause this (idk how rare this is tho)
lets see what everyone else thinks
how many miles? my pump died around 130K
Old Apr 3, 2013 | 07:13 PM
rebelhell's Avatar
Originally Posted by Aviation005
Gobbledygook and gibberish...I have my own Fisher Price tools!
PlaneCrash!! We've missed you!! Welcome back.
Old Apr 3, 2013 | 07:14 PM
rebelhell's Avatar
I apologize for what I've done to your thread. I'm childish sometimes, especially when tired and hopped up on caffeine. Please forgive me.
Old Apr 4, 2013 | 04:58 AM
Ghost_54's Avatar
Does your car only appear to have this stalling issue once the engine has reached operating temp.?
I had this issue with mine a few months back where it only stalled at operating temp. didn't receive any SES code at first and then it gave me P0345 (which is realted to the Bank 2 CPS =cam position sensor). Once changed I have not had the stalling issue anymore.
Just my thoughts on your issue.
Old Apr 4, 2013 | 05:26 PM
gotendbz1's Avatar
yes operating temps. both times it happened was after about 30mins of driving.
is the CPS the on that you have to remove the airbox to get to? or the one in the front of the engine?
Old Apr 5, 2013 | 08:28 AM
Ghost_54's Avatar
What year is your Max? if it is an 02-03 there are two CPS sensors one for bank 1 which is loacted just below the throttle body. The second CPS sensor is located on bank 2 just to the left of the tranny dipstick tube, both are easy to access, to remove push to slide the green tab downward to unlock the harness wiring connector and unclip it and then just a single 10mm bolt holds it in place.
Old Apr 20, 2013 | 04:19 PM
gotendbz1's Avatar
p0340 code what need to be fixed?
Old Apr 20, 2013 | 04:37 PM
Stonelove670's Avatar
If my memory serve me well i believe the p0340 code is Camshaft Position Sensor
Old Apr 20, 2013 | 06:39 PM
Mikel81's Avatar
Yep. P0340 is bank 1 camshaft position sensor or the rear/left one under the throttle body.
Old Apr 23, 2013 | 05:02 AM
gotendbz1's Avatar
this is the one with the big green connector correct?
any guide on how to change this myself.
Old Apr 23, 2013 | 08:33 AM
Mikel81's Avatar
I am pretty sure they both have a green connector. The difference is the back one is straight and the front one the harness comes out at an angle. The job is very easy to do, basically one bolt and one harness.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
