Muffler hitting rear beam??WTF
Whats up im in a 01 AE WITH A 02 SE muffler, muffler keeps hitting the rear beam it's driving me NUTS every big dip or bump. Thump thump!! I've tryed using wire and keeping it tight at the muffler, then right after the muffler near the rear passenger tire, still a thump... Ball joints are new, both axles, shocks and springs, rotors, pads , tires are great
My Megan catback was doing the same thing. You can restrict the movement by taking a hose clamp and tightening it around the rubber muffler hanger that's closest to the rear wheel. No more noise for me after almost a year.
You can also take a piece of rubber hose and put it on the lip of the hump above the rear beam
Here is the trick i used for my cattman exhaust.first i Make sure everything was centered. Then take the crossbeam that your exhaust sits on that's in the middle the car on the bottom it's bolted to the body of the car woth 2 14 mm or 12 mm nuts. Take it off the car and marked the centerline of your exhaust pipe on it then get a piece of reinforcing strap which you can get at Pep Boys it comes in a role in the exhaust section then drill two holes on either side of where the exhaust centerline is Run the strap over Top of the exhaust pipe and then used to bolts and nuts to secure it to the crossbeam your exhaustible no longer move essentially what you are making is a driveshaft loop for the exhaust.
You just need a good set of performance exhaust hangers. They are hard rubber and will not sag and flop around like the OEM ones. I had performance exhaust hangers installed with my 3" Cattman exhaust and NEVER had any problems.
I think it's exhaust hangers too. Replaced all my OEM ones with Walker replacements and that sucker is mounted and not going anywhere lol. Used to sag a lite bit but now looks perfect against the bumper. I would go that route since it's easy and cheap enough
Huttig2009
09-25-2015 03:31 PM
Quickgtp
08-27-2015 02:13 PM
