just installed my HR springs and I'm hearing squeaking noises.....
Old Jan 13, 2002 | 09:46 AM
acMAX's Avatar
i'm hearing these squeaking noises from my rear springs when I go over speed bumps. They don't make any noises at all otherwise.
I just got them installed on saturday.
Is this normal for now considering they're new springs?
Old Jan 13, 2002 | 11:01 AM
CharlieNewbieMax's Avatar
Re: just installed my HR springs and I'm hearing squeaking noises.....
mm..i don't think the noise is normal considering i had H&R springs on my 96, no squeaking noise. Did you install the plastic wraps on the end of the springs? if not, that might be the problem.
Old Jan 13, 2002 | 11:04 AM
Sprint's Avatar
its not the springs.. its the FSTB
Old Jan 13, 2002 | 11:08 AM
could be the RSB
Old Jan 13, 2002 | 11:27 AM
StrongIsleMax's Avatar
How do like they springs? Ride, Handling etc.
Does the rear of the car sag? How is the rear end sag with a full load of people?
I have H&R's just haven't installed them yet.
Old Jan 13, 2002 | 11:42 AM
acMAX's Avatar
it can't be the rsb or the fstb.
I only hear squeaking in the rear section of the car and it
only happens when I go over speed bumps
Old Jan 13, 2002 | 11:44 AM
Sprint's Avatar
thats when most ppl hear the RSB and FSTB problems.. over speed bumps.. i hear mine in the early morning when its cold.. i am just too lazy to go tighten it or investigate
Old Jan 13, 2002 | 11:46 AM
acMAX's Avatar
Re: Re: just installed my HR springs and I'm hearing squeaking noises.....
what plastic wraps? The springs came in the white HR box with nothing else. If you're talking about those things that are on the struts
then yes....they were placed inside them first.
Old Jan 13, 2002 | 12:34 PM
acMAX's Avatar
hey sprintmax
any idea what charlienewbiemax is referring to when he says, "plastic wraps"?
Old Jan 13, 2002 | 12:39 PM
Synki's Avatar
Re: hey sprintmax
http://forums.maxima.org/showthread....8&goto=newpost
There are a few ideas: the bushing on a RSB, FSTB rubbing, Lowering springs (If they are progressive, its most likely the closer gapped coils are rubbing on each other), they didnt isntall the little rubber piece that sits on the spring cups, or when they installed the whole assembly back in, there is a orange gasket that sits between the top of the struts/spring assembly & the frame of the car. Make sure that orange gasket isnt dry & shrivled up.
Old Jan 13, 2002 | 12:41 PM
acMAX's Avatar
Re: Re: hey sprintmax
what if that orange gasket was shriveled up?
would that contribute to the squeaking noise?
So I guess it's safe to say the new springs should not squeak at all?
Old Jan 13, 2002 | 08:02 PM
Synki's Avatar
Well, its actually kind of normal for some lowered car to have noises.
If that orange gasket is all torn up or shriveled up, it means its time for a new one. I have been told this isnt really needed but i have also been told that it does. I still use mine just to be safe. I figured its there for a reason, if not, that wouldnt be there ya know.
Old Jan 13, 2002 | 08:41 PM
emax02's Avatar
I threw away my shriveled up orange gaskets on my 95 when I changed the springs. The car never squeeked though, I don't think that is his problem.
I would have to hear the sound in person to really understand what's going on. Park your car, pop the trunk and push the car up and down and see if you can get a better understanding of were the sound is comming from. Check to see were exactly the noise is being made in, maybe in the trunk? etc.
Old Jan 13, 2002 | 11:39 PM
Re: hey sprintmax
guess someone answered for me already.
dank4us
34
Jun 10, 2024 03:45 AM
95Maxi
35
Sep 2, 2015 10:37 AM
Dasmith
Aug 25, 2015 10:15 PM
MikesChevelle
Aug 7, 2015 05:57 PM
00 Max
Aug 4, 2015 07:09 PM
