leak in 5 M/T 2000
Old Apr 18, 2013 | 05:21 PM
TravisCadello's Avatar
leak in 5 M/T 2000
Has 209k miles but been slowly leakin from where shift linkage goes onto tranny theirs a rubber cover or seal their and it stays soaked in gearoil but if u clean it and feel it its clean and moist not dried out or cracked at all.
where is this oil comming from!!!!! a shop said pull tranny out open it and completely reseal it cause he couldn't see where its commin from.
Old Apr 18, 2013 | 07:14 PM
Max_Gator's Avatar
Make sure it is not coming from the axle seals. From the sound of it, it's input sel and you need a rebuild or new trany soon. Nothing you can do.
Old Apr 18, 2013 | 11:13 PM
Hard to tell where its comming from but pretty sure its not from axels cause the top of shifter linkage seal it dry its leaking from where linkage goes on tranny I'm pretty sure but idk what to replace.
Old Apr 19, 2013 | 07:15 AM
noahrexion's Avatar
A leaking seal doesn't have to be punctured or anything. A tiny leak underneath your car can "look" like a disaster as the airflow from underneath blows the **** all over.
Replace your shift rod seal - you have to punch out the roll pin in the yoke (with boot pulled away) and then the shift rod/linkage will slide out. You could probably just "pic" out the old one and install a new one and hope that solves it. Not expensive and not tough to replace, if you see thats where the leak is coming from it makes sense to replace it right?
Old Apr 19, 2013 | 06:59 PM
didnt know the name and dont even know if its a seal or just a dust boot.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
